Vacuum Bleeder Question
Can a vacuum bleeder be used to bleed the clutch lines? A couple of posts by some members say they have used it, but I have gotten contradictory statements. I just replaced my slave and master cylinder and I'm having real difficulty bleeding the lines the old fashioned way.
Thanks in advance for your help.
To bleed brakes or clutch? Through my research, most say you need a pressure bleeder and not a vacuum as it allows air back through the bleeder. I can tell when I'm bleeding it the old fashioned way that air is going back through the nipple, as I don't have an air tight connection with the tube and nipple. I'm going to look into a pressure bleeder. Otherwise I just might try to get enough pressure to the clutch to get me to a mechanic to bleed it for me. *sigh*
Found this. Great for anyone looking to bleed clutch
http://www.youtube.com/watch?v=wdf--...layer_embedded
Are you closing the slave bleeder when the pedal reaches the floor on every downstroke, AND before allowing the pedal to come up? If you don't you will never get the air out of the system. You do understand that the "old fashioned" bleeding procedure was a two man job? And of course the reservoir fluid level can never be allowed to get down to the bottom and may have to be topped up periodically during the bleeding. Shops use a pressure bleeder because of time, but you should be able to successfully bleed a hydraulic clutch system, or brakes for that matter, at home without a pressure bleeder.
Unclejunebug
Apr 2, 2016 05:42 AM
HerpDerp1919
Sep 29, 2015 02:02 PM
