2000 nissan maxima GLE exhaust
Old May 11, 2009 | 07:33 AM
playtoy's Avatar
Hey peps
Anyone has an diagram of the 2000 nissan maxima GLE exhaust from front to back. My exhaust is making noise and I am pretty sure it has a whole in it. Before I look under the car does anyone have a layout of it.
Also does anyone know a cheap place/site to order parts if i need to replace them. I live in Canada.
Old May 11, 2009 | 01:04 PM
sublime258's Avatar
Old May 11, 2009 | 07:30 PM
CMax03's Avatar
go to Napa they supply the entire exhaust system (Bosal)
Old May 11, 2009 | 10:45 PM
slimbim's Avatar
Thanks for the diagram! I suggest www.autoanything.com, as they have some great pricing and free shipping right now!
I'm looking at getting the following matte finish Magnaflow muffler to replace the stock one on my 2000 Max GLE:
http://www.autoanything.com/exhausts...A2692A0A0.aspx
My questions are:
- Which size do I need to choose from the sizes listed there?
- They state it is "round", but my muffler has an oval profile as in the above diagram. So is this round one the optimal shape?
- What size tip and/or extension do I need to clear the bumper and have clean look?
- Can i expect the same sound from the above unit compared to their other model which is a super shiny polished stainless steel unit?
Many Thanks!
Old May 12, 2009 | 05:14 AM
playtoy's Avatar
sublime258, thank you for that diagram, and CMax03 thanks for that info. I ended up looking under my car to see where exactly is the whole in my exhaust if there is one as it is making a noise when car is in park or pushed on the gas. I could not find anywholes at all. I looked at every inch of that exhaust from front to end and found nothing at all.
Another reason why i looked under because everytime i go over a speed bump or a somewhat bump in the street or even backing up from my drive way and that little drop at the end of the drive way my exhausted or somthing under there makes a loud banging noise like somthing is hitting somthing.
Question
My exhaust is lose when i move it, not that lose but enough that you can move it right to left about 1 cm each. Is that normal or does it need to be tight.
Using the diagram above it looks liike all holders are in place and nothing is missing.
Does anyone have any ideas on what it can be.
Once again thanks all
Old May 12, 2009 | 12:22 PM
sublime258's Avatar
Check the rear flange, it is very common for the exhaust to break right there. Mine broke about 2 weeks after I bought my car, I wasn't happy about it. If you don't see anything broken, your hangers might just be loose.
Old May 13, 2009 | 06:03 AM
playtoy's Avatar
Alright thanks will have a look for sure, as now i think about it, thats where it sounds like its coming from.
Will post result.
Thanks again
Old May 13, 2009 | 04:13 PM
Kevin319's Avatar
Not to threadjack but how do I remove the stock exhaust under this condition??
I sprayed the PBblaster on it and it seems nothing happened. The screws wouldn't budge either. Guess I will have to bring it to a mechanic?
Old May 13, 2009 | 06:20 PM
boondoxmax's Avatar
The shop will torch it off....
Old May 14, 2009 | 05:22 AM
playtoy's Avatar
"Kevin319" Are you having the same issue?
Old May 14, 2009 | 08:35 AM
CMax03's Avatar
You can replace it with a flange system or ball/socket flange system I think magnaflow sells flanges and you pretty much have the muffler shop saw it off or torch it then weld in the new flange assy assembly.
Old May 15, 2009 | 10:42 AM
Kevin319's Avatar
Yeah I am having the same issue. Someone told me I can DIY this but apparently the thing is stuck together. Guess I'll have a shop do this?
Old May 15, 2009 | 11:00 AM
djfrestyl's Avatar
Suspension Yoda
It's spelled HOLE, not WHOLE. Another common location is where the pipe enters the muffler after the axle flange.
xUNIxPanther
Aug 27, 2015 10:09 PM
4doorGTR
Aug 21, 2015 06:19 PM
09maxshawn11
Aug 14, 2015 10:07 PM
niZ
Aug 7, 2015 10:18 PM
julian888
Aug 6, 2015 04:39 AM
