Lights went out
Old May 16, 2009 | 12:43 AM
maxima_on_dub$'s Avatar
Lights went out
I have only been in this forum almost a month and I have been looking for this question but did not see it.
I have a 2003 Max SE 6spd with about 77k miles.
I was driving on night and was coming to a stop and was slowing down then slid on the ice and all my lights went out but the head lights and brake lights. I looked at all the fuses in the dash and checked the relays under the hood and couldn't find anything blown. I switched some of the relays and nothing worked. Does any one have a guess what it could be or seen this problem? Thank you.
Old May 16, 2009 | 06:27 AM
User 12822's Avatar
Check your fuses again, especially under the hood. That sounds really strange though considering you should basically never blow a fuse unless you mess with electrical components.
Old May 16, 2009 | 06:40 AM
Pri63's Avatar
did you check the dimmer switch to see if it's turned all the way up?
Old May 16, 2009 | 11:55 AM
AEMAXIMA01's Avatar
that's my best guess.
Old May 16, 2009 | 01:11 PM
chris in va's Avatar
Hmm. Sliding on ice tells me his ABS kicked on. Maybe it drew too much voltage and shorted something out?
Get your battery tested at Autozone.
Old May 18, 2009 | 09:10 AM
Jreed2008's Avatar
I had something similar happen check my thread to see if its the same problem
http://forums.maxima.org/5th-generat...ights-out.html
Old May 26, 2009 | 02:09 AM
I checked out ur thread and seems like everyone thinks its a fuse. I will go through them again and I might change a couple of them to make sure. Thank you for your help. I will post any findings.
Old Jun 23, 2009 | 10:09 AM
I found a blown fuse in the fuse box under the hood next to the battery. Thank you guys for your help.
Old Jun 23, 2009 | 10:21 AM
Jreed2008's Avatar
Glad 2 hear
Im still trying to figure out why my driver side parking light is still out
Old Jul 14, 2009 | 12:48 AM
CARLOS9827's Avatar
Originally Posted by Jreed2008
Glad 2 hear
My driver side parking light is out also!!! Most of the times is will come on after a few minutes, but now it looks like both parking lights are out. After about 5 minutes they come on even though the headlights have been on the whole time....they are CRAZY and they have a mind of their own!!!
fastcarny
Oct 6, 2015 10:42 AM
DarjeelingRose
Sep 15, 2015 01:20 AM
Maxie40
Sep 14, 2015 11:28 AM
-ReLLiK-
Sep 8, 2015 12:02 PM
Maxima30
Sep 7, 2015 06:13 PM
