02 - 03 maxima ANGEL EYE
Old 05-18-2009 | 08:18 PM
dAAmax's Avatar
hello everyone, i was curious if anyone on here knows the size of the halo rings for our headlights in mm i believe...also does anyone know where i can buy halo rings besides umnitza and not just in white and blue...looking for a 6000k -8000k effect. thanks guys.
Old 05-18-2009 | 08:21 PM
n3985's Avatar
大陆弟弟
The E46 pre-facelift CCFL and LED angel eyes will work fine.
Old 05-18-2009 | 08:33 PM
mist max2000's Avatar
not to step on toes but.. your positive of this even though you have an I and not a max?,.. just curious if you have personal experience from this or going off what you have read,.....also.. bump.. can anyone confirm this?
so your saying these fit?...
http://cgi.ebay.com/ebaymotors/BMW-E...Q5fAccessories
Old 05-18-2009 | 08:47 PM
dAAmax's Avatar
so the BMW E46 angel eyes will fit the 02-03 headlights well? is that what you did?
Old 05-18-2009 | 09:03 PM
n3985's Avatar
大陆弟弟
I know for sure because this isn't the first time someone asked "can I use any other angel eyes besides Umnitza". Other people have confirmed this like The Law, and if you ever compared the 02-03 reflector to the actual ring you'll understand why they fit well.
Old 05-18-2009 | 09:23 PM
dAAmax's Avatar
i understand other rings will fit but im making sure i buy the right rings befor i open the headight. also i cant seem to find rings in an 8000k cathode...mostly all of them are just WHITE
Old 05-18-2009 | 09:30 PM
n3985's Avatar
大陆弟弟
All CCFL are default 6000K white, 8000K is usually ordered. Do you have 02-03 OEM HID headlights or the eBay projectors in your avatar?
Old 05-18-2009 | 09:37 PM
dAAmax's Avatar
i have the 02-03 headlights waiting to be customized big guy
Old 05-18-2009 | 10:19 PM
mannetti21's Avatar
not to hijack here, but are you aware of halos that can be used to replace the halos in Ebay non-projector lights? (ie http://cgi.ebay.com/ebaymotors/00-01...Q5fAccessories)
Old 05-19-2009 | 12:26 AM
M1RAG3's Avatar
I used these for my retrofit:
http://www.retrosolutionsllc.com/ser...yes/Categories
Im not sure what size the rings need to be for OEM 02-03 housings but if you can find out then you can either order the needed size from retro solutions offerings or get them to make you a custom sized set....
All the kits come with 2 extra ballasts (1 ballast powers 2 rings) and the rings are very bright. IMHO they are an excellent alternative to much higher priced umnitza kits
Old 05-19-2009 | 07:45 AM
dAAmax's Avatar
still lookinf for an 8000k look
Old 05-20-2009 | 08:14 AM
Jreed2008's Avatar
By 8k do you mean white with a blue tint?? If so good luck its hard to find an exact color but you can try the place I got mine from.
http://www.automotivelightstore.com/...n=Custom&ID=12
Old 05-20-2009 | 06:56 PM
so .. ill bring this back up... does anyone know the exact size in MM of the needed halos.. should be 2 diff sizes.... i already opened my headlights once for the clear corner and i dont want to do it to measure.. HELP
Old 05-25-2009 | 09:42 AM
dAAmax's Avatar
bump
Old 05-29-2009 | 01:12 AM
Mr. Blue Sky's Avatar
what sizes did you need for the headlights you had on your max? 95mm and 105mm??
Old 05-29-2009 | 02:23 AM
xnyc's Avatar
i can vouch for the prefacelift e46. i have them installed on my car.
Old 05-30-2009 | 08:39 AM
dAAmax's Avatar
are these them?
http://cgi.ebay.com/New-BMW-Bright-A...3A1%7C294%3A50
Old 05-30-2009 | 01:45 PM
xnyc's Avatar
those are for projector headlights. not sure if that would fit. prefacelift means nonprojector. those are the same box that i got mine in though. you gotta trim the tops of those where the plastic peice goes across and they dont fit perfectly. theres a lil bit of overlap with these. not worth the time imho. keep looking for different setups. also check bimmerforums. theyre sponsors carry angel eyes that will work
Old 05-30-2009 | 02:11 PM
n3985's Avatar
大陆弟弟
Prefacelift means pre 2002 for sedans and 2004 for coupes. Actually prefacelift sedan, coup, projector, non-projector, and facelift sedan are the same. I only said make sure to get prefacelift so you don't accidentally get facelift coupe ones which are completely different.
Old 05-31-2009 | 07:13 PM
dAAmax's Avatar
alright...sounds goooddd
Old 06-01-2009 | 01:03 PM
umnitza's Avatar
Former Sponsor
CCFL is so 2 years ago now
The Orion V2 for Maxima (with the correct sized rings now available) are the newest offering:
More with daytime visibility.
Old 06-01-2009 | 01:53 PM
aventerav's Avatar
Go with Umnitza, they look the best.
Old 06-02-2009 | 04:33 PM
nzelinsky's Avatar
I have an '02 SE with HID lights. are the bmw angel eyes the best to go with? The umnitza site doesnt show any angels for the max...
halfpol
10-17-2022 01:16 PM
Goffery2uned
08-21-2015 10:50 PM
MaximaDrvr
08-19-2015 09:20 PM
