Major issure with brakes - ABS light on, Odd sounds, Brake failures
Old May 20, 2009 | 08:25 AM
silvermax2k2's Avatar
Well, it's been forever since I made a post on here, but I am in need of help with some recent brake issues on my 2002 max.
A few months ago I was late to work, and after some "spirited" driving and medium/heavy braking, I went to hit the brakes, and the pedal just went all the way to the floor with minimal brakes. After nearly having a heart attack, I pumped the brake pedal, and some pressure returned to the pedal. I then tested the pedal several times prior to arriving at work, and the pedal continued to go down to the floor. Once at work, I checked the fluid, and it was in between low and full. everything else looked fine. On my way home, my brakes worked fine. Several weeks later, after some heavy braking again, the brakes gave out once more. I took off the wheels, and all brakes have 75% or more pad life in them. So I dismissed it, an just decided to not do any heavy braking anymore.
Fast forward to this morning. Brakes have been working fine all this time. I get into my car, start her up, and the ABS light comes on. Crap. I hit the pedal, and the brakes seemed a bit weak, but they still worked. after driving to work, the brakes still seemed fine, but that ABS light would not go away. Once I was at work, I turned off the car, and then turned the key onto the "on" position, w/o starting the car. I heard something under the hood make a strange noise. I popped the hood, and it sounds like it is coming from the ABS unit itself. I turned the key off, then back on, and it sounds like a pump/grinding/swoosh noise - hard to describe. fluid looks fine.
So here I am. I shut the hood, and I am now writing this, hoping I don't die on the ride home tonight. Other then checking sensors, does anyone have any ideas? I think my ABS unit is shot due to that noise I heard, but I'm trying to convince myself otherwise
Thanks all.
Old May 20, 2009 | 08:28 AM
phatboislim's Avatar
i'm thinking abs unit too..could be master cylinder as well
Old May 20, 2009 | 10:09 AM
You think I can just pull the fuse to my ABS, and I should be fine?
Old May 27, 2009 | 07:13 AM
bmkmcm06's Avatar
I had somthing just like that a few days ago...I pulled the fuse under the hood for a few days then when i had time to look into the problem I pluged the fuse back in and the unit was fine....????.....the only diff is my unit was clicking like the abs was trying to work even when the car was off.....it killed my batt. once...thats when i pulled the fuse
tsi6001
Oct 3, 2022 10:23 PM
AnsonJ
Jun 2, 2017 01:35 PM
homeyclaus
Sep 3, 2015 06:15 PM
egali045
Aug 16, 2015 01:19 PM
Superbform
Aug 11, 2015 08:10 PM
