ABS Light
Old May 21, 2009 | 08:01 PM
CraigsMax01's Avatar
ABS Light
came on last week. checked it with a code reader. the reader showed a few o2 sensor codes but nothing else. cleared codes. light still on.
do i need a certain reader to see ABS codes?
01 max, auto, 213k
Old May 22, 2009 | 05:35 AM
Thorzdad's Avatar
The ABS light coming on doesn't necessarily mean a code will be thrown. Our ABS light came on last year and no code was found. Turned out that the right-rear sensor had failed. Actually, I think it broke.
Old May 22, 2009 | 06:48 AM
Metal Maxima's Avatar
SHIFT_om nom nom nom
You have an open circuit on one of the sensors. Pull the code at Autozone.
Old May 22, 2009 | 09:33 AM
thanks fellas!
will warped rotors cause a sensor to go bad? my fronts are due to be replaced.
Old May 22, 2009 | 09:48 AM
SmokinMax02's Avatar
Autozone doesnt read ABS codes, from what I've been told.
Try a local shop with Evo Genisys scanner (or dealership, which is more $) and they should be able to tell you which ABS sensor needs replaced.
Old May 23, 2009 | 06:35 AM
SteveB123's Avatar
More than likely an open circuit wheel sensor. Open the connectors, and probe them. BTDT.
Standard code readers do NOT work for Nissan ABS.
Old May 23, 2009 | 11:11 PM
hi-tek22's Avatar
^^+1 FOR WHAT HE SAID
Also my ABS light has been coming on and come to find out i have an open circuit at the rear driver side wheel. Im awaiting the part so i can take it to frank hills garage here in baltimore, so he can fix it. I hope it makes the "grinding/pulsation" noise and brake pedal feel go away....If it doesnt im getting rid of the car
Old May 24, 2009 | 04:09 AM
Tippy Toes's Avatar
My rear driver abs sensor has been on now for about 6 months. The dealer wanted a ridic price to put in a new one. I heard the install was tough, I thought all it was was PNP though. Oh well. I'll replace it eventually. RECALL THE REAR DRIVER SENSOR
Old May 24, 2009 | 05:53 AM
Yeah, seriously.
Old May 24, 2009 | 05:56 AM
papo99's Avatar
my drivers rear abs sensor went bad it took me about 10 minutes to change
Old May 26, 2009 | 08:33 PM
i have heard good and bad things, i think if there is dirt and grit in there, it may cause it to be a pain. its a shame places charge so much to read codes.
mvm062
Nov 30, 2020 09:00 AM
bbsitum
Sep 6, 2019 07:31 PM
Maxie40
Sep 14, 2015 11:28 AM
-ReLLiK-
Sep 8, 2015 12:02 PM
maximusrising
Sep 2, 2015 09:55 AM
