Rear Seatbelt LOCKUP
Old May 28, 2009 | 02:41 PM
nishfish871's Avatar
I did the usual bose rattle fix and my seatbelts locked up since i guess they rolled down a bit. Is there a fix for this? i help ASAP bc i cant even get the reardeck back on.
Old May 28, 2009 | 02:47 PM
jasonmax's Avatar
push it in a bit, should unlock it
Old May 28, 2009 | 03:23 PM
It is almost all the way down, it is further than you would if had to "normally" unlock it when everything is installed. All 3 belts are this way. I could try letting it go down a bit more but i really don't have much room unless I unbolt the bottom part of the belt for slack. Is there some type of limit on the belt? More help would be appreciated. Thanks.
Old May 29, 2009 | 08:06 AM
bump i need a solution!
Old May 29, 2009 | 09:18 AM
MadMax07SL's Avatar
Point the car up on a steep incline, or jack up the front end while on the driveway, maybe that will help rock back the lock as you're trying to release it?
Just an off the wall suggestion, I don't know if it's actually going to work for you.
Old May 29, 2009 | 06:08 PM
fixed it...kinda weird how the seatbelt system works. I had to let it go a bit in right before it clicks then pull. I did that a bunch of times then it gave out a little then you have to have the seatbelt unit in the right position that will release it a bit. The right position is like how it is supposed to be orginally installed. Thanks for the help guys.
Old May 29, 2009 | 06:22 PM
Feldman's Avatar
incase you didn't know all of the seatbelts are covered for life through nissan. My rear center seatbelt locked up and nissan replaced it no questions asked
Old Jun 1, 2009 | 09:32 AM
MerlotMax's Avatar
If what you mean by lock is that they will not extend when some one put the belt on? If that is the case, pull the belts out all the way. That should reset them. It is a feature that Nissan put in so a mechanical belt lock was not needed when a child seat is put in the car. When ever the belt is fully extended it will alternate between the two.
matts95max
Apr 23, 2025 10:44 AM
GregL65
Jan 17, 2020 08:01 PM
Y2kMaxima
Wheels/Tires
Sep 14, 2015 10:56 PM
bbsitum
Sep 11, 2015 04:55 PM
