VIAS Delete
Old Jun 16, 2009 | 06:55 AM
bpe383's Avatar
VIAS Delete
I've been searching, and reading a lot on the VIAS delete. Still not sure how it all works. What I haven't found, or read is why someone can't just unplug the vac. line to the plunger. Thus, keeping it open all the time. Is this not the same?
Could you pull the VIAS unit out, take the butterfly valve off and put it back in? This way it looks stock and still appears to be working/intact but isn't.
Old Jun 17, 2009 | 08:38 AM
rmh3093's Avatar
Only gentoo powered Maxima!
I think what you really mean by VIAS delete is the power rod removal. If you are going to run with the VIAS always open you may as well remove the power rod since the rod itself blocks some air flow. People with raised rev-limiters like the upper HP gains from the power rod removal, however, the loss of torque in the low and midrange is not worth the upper HP gains. Midrange really suffers! I ran my max with out a powerrod for a while... when my VIAS broke, it sucks. Just fix your VIAS if its broken.
Old Jun 17, 2009 | 08:47 AM
MoncefA33's Avatar
Do you have a 3.0 or 3.5?
Old Jun 17, 2009 | 08:15 PM
bpe383's Avatar
Sorry about that, I guess it would help to know more about the car.
It's a 2002, 6MT
Thank you
Old Jun 17, 2009 | 10:21 PM
hotstartup's Avatar
i gained a good amount of top end with removalof the VIAS didnt notice much of a loss in low end.
Old Jun 17, 2009 | 10:42 PM
MoncefA33's Avatar
Yeah on the 3.5's the NWP VIAS blockoff plate is gonna give you good high rpm gains.
Removing the power rod is valid only on the 3.0L cars.
Old Dec 23, 2012 | 11:45 AM
MaximusxMaxima's Avatar
hey guys i just changed my valve cover gaskets and after removing the intake manifold i heard a jingle inside of it it turned out to be the butterfly valve or power valve or whatever you call it and was completely off the power rod and the worst part.. the screws were gone... im guessing they got sucked into the engine... just got this car too and now im finding this out. I bought some screws that kind of fit with bolts on the other ends but i dont want it falling off again so could someone give me some advice on what to do now? maybe i should just remove it like you guys said..
Old Dec 23, 2012 | 01:19 PM
TunerMaxima3000's Avatar
Replace the whole thing or remove it
Old Dec 24, 2012 | 04:33 PM
Rods03Max619's Avatar
Remove It, same thing happened to me when I installed my NWP Spacers and found it in the manifold like ****...
trailer54
Nitrous
Nov 18, 2015 07:44 PM
KabirUTA13
19
Oct 17, 2015 02:15 AM
King_Ten_Ahead
Sep 27, 2015 02:24 PM
Dasmith
Sep 23, 2015 08:28 PM
homeofbacon
Sep 23, 2015 07:17 PM
