2k2 power problems
Old Dec 23, 2012 | 05:25 PM
Seattle_Maxima's Avatar
2k2 power problems
hey guys. so I recently had my max die on me twice, at the same gas station, two days apart. so I went into sears auto, the tested it, said it was the battery, and I got a new one. but the lady at the counter said the new battery was a little smaller than the old one, but was better with cold starts. so everything is going well, next morning, I turn it on, put the heat on as well as the seat heater and radio, and start driving. less than half a mile from my house, I revv it a bit, and the tach goes to zero and dies! the lights are still on, and the radio and heat, but engine is off. I turn everything else off, and try to start, and it takes three tries. but the TCS light came on as well as the SES. the TCS has gone away after turning off for a half day, but SES is still on. car seems normal and all, just wondering whether I should get it checked out??? maybe the alternator? thanks for your help!
Old Dec 23, 2012 | 05:41 PM
rebelhell's Avatar
Figure out what codes you have and start there.
Old Dec 23, 2012 | 06:39 PM
fishtale6spd's Avatar
Sounds like the coming cps get codes report back like he said^^
Old Dec 23, 2012 | 07:30 PM
Rods03Max619's Avatar
Yeah get the codes.
Old Dec 23, 2012 | 08:19 PM
sure, I'm going tomorrow to a mechanic friend of mine. Will keep you guys posted. also, recently installed a Weapon-R air intake...think that might be a problem?
Old Dec 23, 2012 | 08:59 PM
maxx0831's Avatar
It definatly sounds more towards the crank position sensor. But like everyone says, get the codes first. It'll pin point you to your problem.
Old Dec 24, 2012 | 06:20 PM
So, went to Sears, they didn't give me the code, but said it was the Camshaft Position sensor bank 1, and would run me 140+ bucks to fix. So, I go down to a mechanic friend of mine, says they're trying to roll me, and that he could clean and reset it and it would be fine, and if need be replace it for cheaper. What do you suggest?
Old Dec 24, 2012 | 06:23 PM
2damax's Avatar
Sonds to me like you already got your answer from this mechanic friend. You will likely be replacing it.
Old Dec 24, 2012 | 07:09 PM
Yeah, was just wondering if anyone had a similar problem in the past... thanks anyways!
Old Dec 24, 2012 | 07:15 PM
Amerikaner83's Avatar
replace.
Old Dec 24, 2012 | 07:29 PM
Has it happened to you before Amerikaner? how much did it run you? hard to DIY?
lowpost99
Oct 26, 2025 06:53 PM
DJLAX152
May 4, 2021 11:46 AM
markevans999
Sep 10, 2015 04:29 PM
slowlifer
Sep 8, 2015 05:53 AM
trungg86
Sep 4, 2015 04:58 AM
