ATTN:REGARDING THE 6th GRN BBK UPGRADE FOR US 5th gens
Old Jun 22, 2009 | 06:42 PM
NissanTun3r's Avatar
The SS lines do work with the 6th gen calipers, the calipers and brackets all line up and bolt up perfectly, if fact everything bolts up perfectly!!
It's a great mod! I just finished mine!
Old Jun 22, 2009 | 08:50 PM
Feldman's Avatar
the calipers bolt up to the original locations correct? no bbk bracket required right? I wish i hadnt just gotten new pads and rotors but oh well i will do this next time around
Old Jun 22, 2009 | 08:53 PM
DrunkieTheBear's Avatar
Turbo'd Saab
but your spell check doesn't work
Old Jun 22, 2009 | 09:06 PM
EnervinE's Avatar
i has college
but you spell check doesn't work
Old Jun 22, 2009 | 09:17 PM
Turbo'd Saab
Originally Posted by EnervinE
where
Old Jun 22, 2009 | 09:18 PM
96blackmaxSE's Avatar
boost me.....
Old Jun 22, 2009 | 10:12 PM
klemenz's Avatar
i'm thinking about going to the junk yard and pulling the brakes off a 6th gen to put on my car whenever i change the rotors and pads. from what i understand it doesn't work with the stock rims but if you get 10mm spacers it does.
Old Jun 22, 2009 | 10:20 PM
Turbo'd Saab
Originally Posted by 96blackmaxSE
Old Jun 22, 2009 | 10:44 PM
PulsarGTS's Avatar
In a different thread, it was said that oem 02-03 17" will clear and oem 00-01 17"s wont.iirc. As cheap of an upgrade is this is, its very tenting.
Old Jun 22, 2009 | 10:55 PM
OOmaxSE's Avatar
So it's a direct bolt on with no caliper bracket? I thought this was only the case for 5.5 gens...
Old Jun 23, 2009 | 09:59 AM
EVERYTHING IS DIRECT BOLT ON, but you need 6th gen caliper/bracket/pads/rotors
you CAN use your 5th gen brrake line
Old Jun 24, 2009 | 10:43 AM
sergey85's Avatar
so is this better than the oem set up cause it looks the same as the 5.5 gen?
Old Jun 24, 2009 | 10:46 AM
secondtonone317's Avatar
nycnissans
yes it all fits right on
Old Jun 24, 2009 | 11:05 AM
PulsarGTS's Avatar
Check out the how thread. The rotor has alot more contact area.
Old Jun 24, 2009 | 11:16 AM
NmexMAX's Avatar
dot dot dot ...
Rotor is larger & Caliper is larger. Added weight is the only drawback.
The A33B rotor is, IIRC 11.8", and the A34 is 12.6".
Old Jun 24, 2009 | 12:01 PM
SoulEater's Avatar
if you wanna use SS lines, which SS lines do you use? Is it for 5th gen's brakes or 6th gen's one?
if i recall, the part numbers for those two gens are different, according to goodridge catalogue. http://www.goodridge.net/usa/documen...ustomerver.pdf
5th gen part # is 22133
5.5th gen part # is 22134
6th gen part # is 22134.
Old Jun 24, 2009 | 01:28 PM
NmexMAX's Avatar
dot dot dot ...
Use the lines for the chassis, not the calipers. if you have a 5th gen, then so on & so forth.
Old Jun 24, 2009 | 06:23 PM
Tee00Max's Avatar
definetly will be done in the next couple weeks...i already need new rotors....
Old Jun 25, 2009 | 05:18 AM
Prophecy99's Avatar
http://i529.photobucket.com/albums/d...7/DSCN1692.jpg
What Rotors are those? How much? I have been looking for the exact "oem" style with the center hub area black.
Old Jun 25, 2009 | 05:25 AM
Puppetmaster's Avatar
I don't know what he has, but FYI, Centric/Cryo-Stop blank rotors look like that. I have Cryo-Stop rears.
MAXSE5SPD
Sep 17, 2022 04:00 AM
BkGreen97
Apr 2, 2016 05:47 AM
Violator
Sep 9, 2015 10:14 AM
