03 max spark plugs info
Old Jun 25, 2009 | 08:05 AM
maxs4life's Avatar
I have an 03 maxima Se, and i need some information regarding spark plugs. My local mechanic talks to much and i need to understand him when he speaks.
When i first got my car i had my girls brother change my spark plugs. He is a mechanic and he did the job for free so i was content. He has all the tools so i thought i was coming off with a great deal.
Anyways I took my car to my regular mechanic and he said that my spark plugs were put in wrong, or something about the degrees of the spark plug being wrong.
Is my mechanic right?
Info on how to put in and whats right and wrong.
Old Jun 25, 2009 | 08:15 AM
NmexMAX's Avatar
dot dot dot ...
There are some myths / theories, etc. as to how they are clocked with respect to their electrode vs where the combustion chamber is. IMO, it doesn't matter. Doesn't / wont make a huge difference. Just torque them down to their proper specs & you should be fine. (I don't even do that anymore )
Old Jun 25, 2009 | 09:04 AM
MadMax07SL's Avatar
Is he talking about the gap? Becuase that's got to be right for the motor to get proper combustion. Gap too big, spark may be late, to small, not enough spark. Either way will lead to a rough running motor.
Old Jun 25, 2009 | 12:39 PM
NmexMAX's Avatar
dot dot dot ...
If the plugs are for the A33B Maxima, i.e. correct plugs were used, they need no gapping.
Old Jun 25, 2009 | 02:35 PM
Col Ronson's Avatar
changing the spark plugs on a VQ35 isn't easy. It might've been installed wrong. But are you having any performance issues? misfire issues? if not, then everything should be ok.
Old Jun 25, 2009 | 02:38 PM
HotshotVQ35's Avatar
how do you install a spark plug wrong? cross threading is really the only way i see it, and you have to be a real dumba$$ to do that!
Old Jun 25, 2009 | 03:27 PM
NmexMAX's Avatar
dot dot dot ...
Old Jun 25, 2009 | 04:23 PM
Child_uv_KoRn's Avatar
Bad *** Newb
Mechanic probably knows jack about nissans and imports in general?
Most that I see are dumbfounded when they learn the engine design. Are the domestics that far behind (besides the ones that use jap engines lol)?
mvm062
Nov 30, 2020 09:00 AM
9aj9
Apr 5, 2020 12:11 AM
minsbang
Sep 11, 2015 08:48 PM
