Harder to stop =/
Old Jul 8, 2009 | 06:15 PM
  #41
MidN1te's Avatar
Originally Posted by Matt93SE
IS there *anything* you did to the car near the same time as when this started to occur?
negative.. i have not touched the car minus lowering the car.. never touched anything else.
Did they do the brake job and THEN this happened, or within a few weeks of them doing a brake job?
what about engine work? Have you done anything under the hood recently?
when i bought the car, i noticed the car had baaaad rotors so i had them replace the rotors and pads...even then they only grabbed a little better than it does now...no engine work at all.
Did this just immediately happen and stay this bad, or has it been slowly getting worse over time?
i believe i noticed this slowly declining.. it does feel like sometimes it grabs better on cooler days than it does on hotter days...
what brand and type of brake pads did the shop install on the car when they did the job?
(If you don't know, then it was probably the $19 junk pads at Autozone and they're absolute crapola.)
the brake pads are the cheapies... duralast.. i'm sure they arent ceramic.. but again.. wat gets me is that when i first had this problem in my other 2002 maxima with the same round about mileage, i replaced with axxis pads, crossdrilled/slotted rotors and had the brakes bled as well..
Has the car ALWAYS been like this, or you've had the car for years and this started recently?
i purchased the car back in January... and the car did feel more powerful then.. i'm not sure since its cuz its hot now that its just not as powerful and now has 109k on the car... i think i may need to change the plugs now.. and also i know that this car burns oil.. since its the vq35, they do that.. but when i put new fresh oil and or oil change.. the car feels more peppy but the brake feel doesnt change... i also checked the lines to see if there is any leakage.. non.. as a matter of fact.. the fluid is above the MAX line... and no hoses have been removed nor anything missing from what i can see..
Old Jul 9, 2009 | 02:30 PM
  #42
SteveB123's Avatar
Originally Posted by MidN1te
well... i dont know hahaha..
soooo.. it made sense to me that if i replaced all 4 of the release valves with speed bleeders, i would just turn them all 1/4 turn, keep pumping the brakes while making sure i keep filling up new fluid in the master cylinder untill all new fluid has replaced the old... then close up the speed bleeders..
Well, yes, it'll work....you'll need four pieces of hoses on the bleeders, and four containers for the ends of the hoses, of course, or you'll have brake fluid over all and sundry.
Old Jul 9, 2009 | 03:20 PM
  #43
nzelinsky's Avatar
omg lol bleed them one at a time or your going to have alot of problems. Also, dont overfill the reserve thats not going to help your problem any.
Have somebody else pump your brakes and inspect the calipers for motion one at a time. Also, check the power going through the brakebooster/master cylinder and see if its working properly
good luck
Old Jul 9, 2009 | 03:43 PM
  #44
MidN1te's Avatar
hahahaha... i was just throwing that theory out there guys..
most likely i'll just have the wifey pump the brakes while i just bleed them... just much more "eyes on" as you said nzelinsky...
we'll see where that goes first... man.. i just hate NOT knowing whats the real deal considering i been through this already with my last maxima =/
Old Jul 10, 2009 | 05:39 AM
  #45
Norm Peterson's Avatar
Actually, I'd think that it would be nearly impossible to guarantee anywhere near equal flow rates out all of the bleeders at the same time. The ones with "lazy" flow would take longer to clear and you'd only be throwing a lot of fluid away out the good-flowing ones.
Norm
Old Jul 21, 2009 | 12:48 AM
  #46
ridinwitha35's Avatar
I just installed SpeedBleeders on my front calipers. I did more of a flush than a bleed with Valvoline DOT3/4 fluid (one caliper at a time though). Took about 4-5 sets of 8 brake pedal pumps. 1 set = # of pumps before the master cylinder fluid was half-way & I had to top it off. Old fluid had a lot of black stuff in it.
End result: brakes bite much earlier and harder. I say just flush your fluid...it can only be for the better.
PS: Make sure you close the SpeedBleeder as tight as possible so that it doesn't put out fluid when you think you tightened them to the "close" position & you brake. Test that before you actually need to use the brakes, and also check your fluid level after a good drive!
Old Jul 21, 2009 | 01:09 AM
  #47
viperboy's Avatar
I seem to have had this problem all along since I got the car. I changed out the rear rotors and calipers cause they were going and replaced the front brake lines because they were going too and my pedal always feels soft to me. Like I can put the pedal to the floor without much force, especially when stopped.
Also, when the brakes get wet - be it rain or a car wash, the brakes feel even softer. Anyone have any ideas? It's not a big problem, maybe the brakes on these Jap cars are so different from my VWs that it's just odd to get used to.
Old Jul 26, 2009 | 04:08 PM
  #48
SteveB123's Avatar
Reason for a recent rear caliper change:
Nice piston, eh?
Originally Posted by NmexMAX
Ya, but IMO, I don't think it's a seized caliper. Not sure where that logic came from.
Just a lucky guess.
Old Nov 8, 2009 | 05:08 AM
  #49
MidN1te's Avatar
UPDATE....So yesterday... I installed Brand cross drilled/slotted rotors, new ceramic brake pads, New Goodridge SS lines... AAAND ALL 4 brand new oem calipers... obviously new fluid...
The car does grab better... it feels like it stops better...
but it still doesnt have that initial push...
i dont know if the brake master cylinder is goin? but i dont know what it would feel like if it does...
i guess i could replace that too but i might as well replace the brake booster while doing so.
but my brakes do feel alot better...
Old Nov 8, 2009 | 05:19 AM
  #50
Rochester's Avatar
...but my brakes do feel a lot better...
Hey MidN1te, congrats on your new brake setup.
Did you paint those new OEM calipers before putting them on? The surface on the OEM's is so crude, I've always wondered if they could be successfully bead-blasted first.
Old Nov 8, 2009 | 06:36 AM
  #51
MidN1te's Avatar
Hey buddy! Yep, just used red caliper paint. Works very well. I just washed the calipers first with some purple power and dried them so they were greasless then i just sprayed them. Worked like a charm!
Hey do u know of a write up on how to change the brake booster and the master brake cylinder? Think that may be my culprit. I mean hell ecerythibg else is frick new lol
Old Nov 8, 2009 | 06:54 AM
  #52
Rochester's Avatar
I can't help you there. Sorry I went OT on your brakes, but I'm curious about painting the OEM calipers. Looking through your thread, it sure reads like your problem is in the master cylinder. Good luck, man.
Old Nov 8, 2009 | 07:39 AM
  #53
MidN1te's Avatar
yea i've painted a few calipers.. very easy and looks good just make sure you clean well with purple power and a rag.. and let it thoroughly dry..
I just found the brake boost And brake master cylinder for 265 shipped so i'mma grab those and just replace... if that doesnt do it... not sure what will hahaha.. the vacuum lines seem just fine but i'll replace that hose that goes to the booster as well just incase...
Old Nov 8, 2009 | 11:47 AM
  #54
FlipCpt45's Avatar
hmm.. it could just mean you need SS brake lines.. the original rubber lines or w.e could be expanded and taking out line pressure... my mom's 96's brake pedal feels better than my 01.. Nobody drives that car hard.. unlike my car lol
Old Nov 8, 2009 | 03:03 PM
  #55
I found that a slight adjustment of pedal height helped the brake feel in my 20AE (2001) considerably.
I cannot over-emphasize the word "slight" here. Adjust the pedal up too much and they'll lock up solid from thermal expansion effects.
I also don't really know why it worked, but it did.
Norm
Old Nov 8, 2009 | 04:38 PM
  #56
MidN1te's Avatar
I did... i replaced the lines to SS goodridge, brand new calipers, new ceramic pads, new crossdrilled slotted rotors..
the BITE is there.. but its lost its extra OOMPH..
Old Nov 8, 2009 | 10:04 PM
  #57
crazy97's Avatar
Did you bed them in? Doesnt sound like you did.
http://www.zeckhausen.com/bedding_in_brakes.htm
Clean off the oil on the new rotors before install??
Old Nov 9, 2009 | 04:49 AM
  #58
I'm not convinced that a ceramic pad will feel as good as a semi-metallic or ferro-carbon pad. Not yet, anyway.
The clear advantages of ceramic are in low noise, low dusting, and low rotor wear rates.
"Ceramic" seems to be the new buzz-word that implies that it's a be-all, end-all solution to everybody's braking needs. It's not. Buy them for the right reasons, look elsewhere if your needs differ.
And whatever pads you end up with, do bed them in properly.
Norm
Old Nov 9, 2009 | 05:06 AM
  #59
MidN1te's Avatar
Yes...i've done all my rotors and pads this way. I do this especially on my turbo s2000 for racing purposes...
that's the first thing i do when replacing new brakes...
but thats good you brought that up because not many people know about bedding..
Old Nov 9, 2009 | 05:10 AM
  #60
MidN1te's Avatar
Norm
other than the clear advantages you stated, the ceramics DO feel alot different than semi-metallic. I can definately feel the bite is harder and smoother. On the semi-metallic, it grinds more and the feed back you get from the two are actually very noticeable.
That's on the maxima as well as my turbo s2000. I've done a few cars and i've never looked back. They are definately worth it. Even the Wifey said its noticeble when she drives the 2 cars.
Ofcourse this is all by feel, and not raw data. But doing the racing and driving I do, feedback from the car is very important and the cars definately talk to me and let me know what they like.
Old Nov 9, 2009 | 05:24 AM
  #61
MidN1te's Avatar
mind you at around this mileage of 110 or so, my old 2002 maxima did the same thing.. changed all the brakes rotors, bled and bedded and everything... Same results...
My cousins 03 maxima has 60k on it now... i remember a couple years ago the brakes were awesome.. but its starting to slowly not be as strong as it used to be even with their new brakes...
On my old 2002, i never got to replace the master brake cylinder and booster so i never got to know if that was the fix..
I guess i'll just have to get these and see if that does the trick
Old Nov 9, 2009 | 02:24 PM
  #62
crazy97's Avatar
My 03 was the same way when I bought it at 94K. Almost had to stand on the pedal to stop the car. Put Hawk hps on and it stops with amazing ease even after 20K. On tirerack they rate the Hawk semi metallics 4 stars for stopping power and the Hawk Ceramics only got 3 stars for stopping power.. Maybe its the pads you are choosing?
Old Nov 9, 2009 | 02:45 PM
  #63
MidN1te's Avatar
that's funny. I've had hawks metallic's, ceramics, stock, other semi-metallics, and finally axxis which has been the best out of all the ones i've ever tried...
the ones i just had on the maxima were semi-metallic and those bit worse.
i mean the thing is.. the bite is there... its biting.. its just the force behind the bite isnt there anymore... the aid and assistance isn't there.
which leads me to believe its the booster.. *shrugs*.. i mean i could be wrong obviously.. but my last maxima was the same..
Old Nov 9, 2009 | 03:07 PM
  #64
unrealii's Avatar
Give the brakes some more time to break in. My brembo slotted/hawk hps setup sucked for the first 500-1000 miles, then suddenly became totally awesome.
Notice how many of them are saying to avoid heavy braking for 400-500 miles:
http://www.tirerack.com/brakes/tech/....jsp?techid=85
I would still do the bed in proceedure corresponding to your pads.
How long did all of that take you to do? I'm doing the same on the front: lines, calipers, rotors, pads and just lines on the rear, then bleed all old fluid out. I have all the parts, just haven't done it yet.
Old Nov 9, 2009 | 03:43 PM
  #65
StenholmEngineering's Avatar
just as a lil help make sure the vacuum like that runs to the booster is A) connected/all the way on and B) doesnt have a hole. i forgot to hook one up on a car and it was a bytch to stop...lol
Old Nov 9, 2009 | 05:58 PM
  #66
MidN1te's Avatar
Yea, sometimes TIME actually makes a difference when it comes to stopping power. meaning more miles.. which is true...
i'm giving it some time and miles for now. but yea i've bedded them properly
the whole process maybe took about 45min to an hour? Very easy to do.. ESPECIALLY the bleeding with the speed bleeders... LOVE those things..
Old Nov 9, 2009 | 06:00 PM
  #67
MidN1te's Avatar
LOL.. yea i'll double check.. but i've looked at the hose before and it was connected and appeared to be in good condition... but yea i can imagine that "oh ****" feeling you get when it doesnt wanna stop hahahaha
Old Dec 23, 2009 | 06:18 PM
  #68
unrealii's Avatar
Just curious, did that initial push come back? I recently did a 6th gen bbk upgrade, but downgraded pads from hawk hps to monroe ceramics. Initial bite isn't as good as the hawk. Wanted to see how yours was coming along.
Old Dec 23, 2009 | 08:22 PM
  #69
Scottwax's Avatar
That's Mr. Detail to you
All this is very odd. I just past 166,000 miles on my car and other than a pad change (Pro Stop ceramic pads), my car stops like I dropped an anchor out the back. Definitely the quickest stopping car I've ever owned. Just now getting a touch of flutter when I hit the brakes at higher speeds but not around town yet so I'll probably be replacing the rotors in the next month or two.
If you haven't done a brake fluid flush and checked the booster and lines for vacuum leaks, I'd do that. Sounds like all the hardware is in really good shape.
Old Dec 24, 2009 | 12:47 PM
  #70
maxout!'s Avatar
Hey folks... not sure if this applies to any other gen... but this happened in my last 2002 maxima as well..
well the car's brakes feel kinda...well i have to push down the pedal alot more and it feels like the car is stopping by MY own foot versus before you push down a lil and the car would slow itself, like the brake booster would help.."if thats what its called" so since i had the problem last time in my other max, i changed the fluid, the brakes to ceramics, powerslot rotors... and it really didnt make much of a difference..
so this time around i'm having the same symptoms... i really dont knwo what to think... i tried to search but nothign really specific cept doing what i just did last time on my other max that didnt fix anything...
im lowered, new strut mounts ect... and the car doesnt dive or lift when braking or accelerating.. its smooth...umm...
ionno.. isnt there something in the car like a brake booster or something that helps push the brakes more for you? feel like i'm manually stopping my own car now... like.. the flintstones lol
btw... i never touched the brakes...... never broke the lines or anything..
Just do what I usually do when the brakes don't work as well as they should. I kick ze door open & put me foot down to drag ze car to a stop.
Old Dec 27, 2009 | 07:11 PM
  #71
billygeg's Avatar
If your brakes go all the way to the floor and you really have to press hard the probably need bleeding. First check your fluid level then bleed them. Its not hard and should take about 10 minutes per wheel..You need two people though.
D Mason
Jun 21, 2016 04:43 AM
BobTX10
Oct 7, 2015 08:43 AM
HerpDerp1919
Sep 29, 2015 02:02 PM
salty318
Sep 29, 2015 01:21 PM
salty318
Sep 28, 2015 07:22 PM
