Rear strut is shifted out of place...pics
Old Jul 7, 2009 | 12:08 PM
  #41
DanNY's Avatar
Ad·min·is·tra·tor
do you have aftermarket sway bars?
Old Jul 7, 2009 | 12:19 PM
  #42
mannetti21's Avatar
no sway bars. Just had a thunderstorm here and the squeaking seems to have ALMOST went away. Still slight squeak with heavy spring compression over speed bumps...from what I've read on here, usually if its the spring, rain/wetness will usually temporarily solve the problem, true?
Old Jul 7, 2009 | 12:32 PM
  #43
DanNY's Avatar
Ad·min·is·tra·tor
shoot some white lithium grease around the mount and spring seat and see what happens.
the water/dampness acts like a lube so you don't hear it as much when it's wet out.
Old Jul 7, 2009 | 12:46 PM
  #44
mannetti21's Avatar
I was actually wondering about that since I've done it before...about 1 day before the problem really started to get bad. Not sure if there is anyway that spraying the white lith up into the mount could possibly screw something up....
I'll give it a day or 2 to dry out and see what happens. If it comes back, I'll spray some more grease
Old Jul 7, 2009 | 12:58 PM
  #45
max929's Avatar
Any chance that the spring is cracked/damage?? If the strut is not damaged and you have a new top mount then the common denominator is the spring. Just food for thought, you can rent a spring compressor from autozone for free (you have to leave a deposit which is returned)
Old Jul 7, 2009 | 08:51 PM
  #46
CMax03's Avatar
Dam you could've had it fixed by now! Just jack it up and get after it....You're there not us!
Huttig2009
Sep 25, 2015 03:31 PM
iflexsteel
Sep 15, 2015 03:37 AM
MaxStock
Aug 14, 2015 09:59 PM
MaxStock
Aug 8, 2015 01:18 AM
laparka66
Aug 6, 2015 09:36 AM
