Overheating Part 2
Old Jul 14, 2009 | 06:10 PM
Col Ronson's Avatar
Overheating Part 2
So as some of you know my car has this funny issue where it starts getting hot when idle and the A/C goes from cold air to basically a heater.
I let the car purposely run the temperature up in my driveway and observed. the A/C fan was spinning as expected. the fan to the right, the other radiator fan was not. Yikes. Theres' most likely the issue right there.
Any guesses how much to fix? i've been ignoring it because i have no money. But its getting annoying starting my car and having it blow out hot air already when its 112 degrees outside and its been parked for 6 hours.
I could do it myself, but what parts would i have to buy? just a new motor correct??
Old Jul 14, 2009 | 07:09 PM
johnnyd2k2's Avatar
I'd check for power to the motor first, but I'm not really sure how to diagnose the problem, it may not be quite that simple. I'm sure someone will step in to further help you out. Anyway here is a link to get the motor if thats the issue. Part #21591+A (passengers side)
http://www.courtesyparts.com/maxima-...1981_1987.html
Old Jul 14, 2009 | 07:44 PM
SteveB123's Avatar
Jump the motor to the battery, if it spins, motors good, you've got a motor control issue. Temp sensor or relay would be my bet.
Old Jul 14, 2009 | 08:48 PM
Col Ronson's Avatar
how the freak would i do that?
Old Jul 14, 2009 | 09:50 PM
ridinwitha35's Avatar
pin 3 to battery.neg, pin 2 to battery.positive (for low speed)
or
pin 4 to battery.neg, pin 1 to battery.positive (for high speed)
Old Jul 14, 2009 | 09:56 PM
foodmanry's Avatar
Da Roller Coaster!
Use jump it from those pins to the battery terminals with wires. You need two wires (one for positive and one for negative).
or
Old Jul 14, 2009 | 09:57 PM
foodmanry's Avatar
Da Roller Coaster!
By the way...if it is the motor you can probably find it cheaper online. I had to buy one, but I can't remember where I got it. It was around $120.
Old Jul 14, 2009 | 10:53 PM
Col Ronson's Avatar
you guys are awesome thanks for that i'll try it tomorrow. I want to check my relays too because changing the motor is something that i dont wanna take the effort to do. However the relays are in such a tight space and i have no clue how to remove them, short of breaking the thing.
any suggestions? maybe a step by step picture guide for my moron mind would help =D
derekinthez
Nov 13, 2022 04:00 PM
97_GXE
20
Sep 17, 2015 08:12 PM
97_GXE
Sep 15, 2015 06:47 AM
asianstyle
Sep 10, 2015 11:30 AM
videomano
Sep 8, 2015 03:28 PM
