Help Needed about Bushing!!!!
Old Jul 21, 2009 | 10:30 PM
Tee00Max's Avatar
Ok i have been hearing a loud banging noise coming from my suspension when i would hit a bump or anything in the road and its been annoying the he** outta me for a couple of months now so my and my boy got under the car today and came across this bushing where the noise was coming from...
this bushing was right in front of the passenger rear wheel on what is the trailing arm???? maybe (if thats what its called). The picture is the picture of the bushing thats on the driver side and still intact while the passenger side one was busted and the grease was all leaked out, I really want to know what this bushing is called or a proper name for it so i can go about getting another one, so if anyone knows what this bushing is called i would appreciate it and if replaced can you get it from an autoparts store or from nissan only, thanks.
Old Jul 21, 2009 | 11:01 PM
Tee00Max's Avatar
ok well i found out that its called the torsion beam bushing and by the looks of the write-up its seems like alot of work. Has anyone replaced this and if so, please tell me that you didnt have to take off the whole rear assembly..
Old Jul 22, 2009 | 05:55 AM
bucketman's Avatar
Sounds like my problem on my 02-SE Dealer identiied it as "rear suspension beam bushing (55501-6Y300) suspension beam cost to replace $1359.00 (5.0)hrs?" you must drop suspension and replace been told.
If that is your problem you can get the complete rear beam suspension for a max 2000 3.0L(SES) for about $454.86 according to Courtesy Parts click on link and identify your part http://www.courtesyparts.com/maxima-...2046_2050.html
Hope this helps, lets us know what you do-Good Luck
Old Jul 22, 2009 | 07:32 AM
Tee00Max's Avatar
I just feel like i really dont need to replace that whole beam just for that damn bushing...
Old Jul 22, 2009 | 01:47 PM
Tee00Max's Avatar
anybody?????? really need some input on this.
Old Jul 22, 2009 | 02:05 PM
pmohr's Avatar
No more Maximas...
Did you search?
http://forums.maxima.org/5th-generat...g-leaking.html
Old Jul 22, 2009 | 03:52 PM
SteveB123's Avatar
Bushing replacement procedure:
http://www.energysuspension.com/pdf_instruc/17427.PDF
Old Jul 22, 2009 | 04:35 PM
Tee00Max's Avatar
yea i searched but just wanted some more input on the procedure if anyone up here has been through this..
Old Jul 22, 2009 | 04:42 PM
pmohr's Avatar
No more Maximas...
Looks like a fairly clearly written procedure to me
Even written out step by step.
Old Jul 26, 2009 | 01:07 PM
g.sembhi's Avatar
i've read lots of posts about this, it's not as easy as it seems, on my car both sides are shot, it doesn't bother that much but if i want to change i'll rather change the whole beam than the bushings! also my mechanic told me that if would take forever to change the bushings!
check out this link
http://forums.maxima.org/5th-generat...ings-pita.html
Old Aug 25, 2009 | 10:32 AM
irish44j's Avatar
retired moderator
Personally, I would just go to a junkyard and get the entire beam (assuming the bushigns look good in it). I went 150k on my maxima with alot of track work and never had issues with those bushings, I think you were just unlucky.
It will cost less and be less hassle to just install a junkyard beam. Otherwise you have to press the old ones out and new ones in (do they even make replacement bushings?)
Dropping the rear axle is difficult and time-consuming but not impossible...
Old Aug 25, 2009 | 01:24 PM
SmokinMax02's Avatar
A rear beam from a junkyard is going to cost you anywhere from $125-150. In my opinion, you really are taking a chance on how good of shape its in until its actually on the ride.
OTOH, the trailing arm bushing set from Energy Suspension is anywhere from $55-75, depending on what online dealer you get it from.
So although the install might be a little more time consuming than just installing a junkyard beam, its definitely worth the peace of mind to go with new ES bushings if you can do it yourself.
Here is the step by step on how to do this procedure:
http://www.digitalpolo.com/2002MaximaSE/EnergySuspension/TrailingArmBushings/Energy%20Suspension%20Rear%20Trailing%20Arm%20Bush ing%20Set.htm
Good luck
Old Aug 25, 2009 | 03:50 PM
irish44j's Avatar
retired moderator
Ah, I need to look closer next time...I was thinking he was talking about the bushigns in the central (panhard) assembly.
Matt93SE
May 24, 2019 02:58 PM
smplyamzng
Dec 13, 2015 01:19 PM
homeyclaus
Sep 3, 2015 06:15 PM
TonyJr
Aug 20, 2015 12:14 AM
00 Max
Aug 4, 2015 07:09 PM
