nwp spacer reapplication
Old Jul 29, 2009 | 05:42 PM
ckent512's Avatar
What is the best way to remove used rtv from NWP spacers? I am going to reuse them after I do some other work.
Old Jul 29, 2009 | 06:10 PM
infinitiblast's Avatar
Razor Blade is the best. Just hold it steady and dont cut into the spacer any. If it getting dull get a fresh blade, using a dull blade will cause you to apply more force and possibly nicking injuring the spacer.
Old Jul 29, 2009 | 06:14 PM
ckent512's Avatar
thanks for your reply. i did that, but their is still a slight residue. Is their any sort of safe cleaning solution that someone could recommend?
Old Jul 29, 2009 | 10:18 PM
Unklejoe's Avatar
I had the same problem. I tried goo gone and rubbing alcohol with no luck.
I ended up putting one of those little cotton ball things on my dremel and basically buffing all the used RTV off.
Old Jul 29, 2009 | 10:23 PM
ojeda112's Avatar
Thanks for the idea. Im also in the same situation
Old Jul 30, 2009 | 10:13 AM
ckent512's Avatar
I e-mailed Aaron at NWP and he said " I would recommend using a gasket scraper
that will not scratch the Spacers deeply. I like using a plastic gasket
scraper to get most of the old RTV off. Then, you can use acetone or
brake cleaner to help soften the rest and use a rag. But in most cases, I
am able to remove all the old RTV without using any chemicals. The
plastic gasket scraper gets it all. Then I wipe it with a dry rag and
reapply RTV.
I like scraping the RTV when it's fully dry without using any solvents. A
metal gasket scraper will work just fine. Just make sure you don't cut
into the Spacers or gouge or scratch it badly."
Old Jul 30, 2009 | 05:09 PM
k2a2b's Avatar
I wonder if caulking remover would work and not hurt the spacers?
They make solvents for silicone caulking, you can pick them up at any hardware store...
Old Jul 30, 2009 | 05:25 PM
knight_yyz's Avatar
Toolie
acetone worked the best for me, brake cleaner didn't even come close to helping
coolsun
Wheels/Tires
Oct 15, 2015 10:52 PM
NewMax03
Oct 7, 2015 08:27 AM
Lowered_a33
Sep 10, 2015 09:41 PM
Maxboy23
Sep 9, 2015 10:37 AM
Maxboy23
Sep 4, 2015 06:04 PM
