Need help disabling factory alarm.
Old Jul 30, 2009 | 08:01 AM
cajun1104's Avatar
I have a 2000 gle. i have an Aftermarket generation alarm. The problem is that every few days the factory alarm wont disable when the other one is and goes off when the doors are open. I have to carry the stock key fob to turn it off. Is there any way to disable the factory alarm?
Old Jul 30, 2009 | 08:16 AM
The6spdMax's Avatar
Pretty sure you can. Just find the factory wiring diagram and cut off the power source for the factory alarm to disable it.
Old Jul 30, 2009 | 10:43 AM
Col Ronson's Avatar
just pull the factory alarm fuse??
Old Jul 30, 2009 | 01:38 PM
Ghost_54's Avatar
Depending on which aftermarket alarm you went with (mine is a Viper) your stock alarm system can ( or should have been by the installer) hook in to the aftermarket system, as it now becomes the primary system and the factory on is like a back up. I have had no issues with system activating or disarming. I would go back to who did the install as it sounds like they have screwed up the wiring.
Old Oct 20, 2009 | 12:03 PM
H8tank's Avatar
Our factory Keyless/alarm quit working, dealer wanted a bunch of cash to tell me it was going to cost a lot more cash, so I added an after market keyless entry w/remote start. It was professionally installed.
Now however, for no reason, the factory alarm will sound at random times, key in the ignition will not disable it. I am still searching here for a solution, but if it is as easy as pulling the factory alarm fuse, let me know, thanks!
Old Oct 20, 2009 | 12:32 PM
TLMNICK's Avatar
Whoever did the installation did not hook up the "disarm" wire as they should have. There is a module under the dash called the "smart entrance control unit".
There is an orange/blue wire in one of the harnesses attached to it. This is the factory disarm wire. If that wasn't connected by the installer who did your aftermarket system, then you'll end up with the problems that you're experiencing.
Here is a picture of what I'm talking about. The DISARM wire is the one you're looking for.
Old Oct 20, 2009 | 12:38 PM
Ghost_54's Avatar
Your the best Nick, I knew you would have the answer for the OP
Old Oct 20, 2009 | 12:48 PM
H8tank's Avatar
Can I just cut that wire? I don't really need the alarm.
Thanks for the info!
Old Oct 20, 2009 | 02:30 PM
Ghost_54's Avatar
As the alarm wire is part of the system cutting it would be sensed as tampering and would probably shut down your whole car ignition system, so personally I wouldn't recommend cutting it.
Old Oct 20, 2009 | 02:34 PM
01GLEMist's Avatar
Mmmm....Astrochart spec sheets
Old Oct 20, 2009 | 06:22 PM
TLMNICK's Avatar
IF you cut that wire, then you'll have no way to disarm the stock alarm system other than the stock remote. Leaving that wire intact will allow you to disarm it from the driver door as well.
Look under the dash of your car. There should be a wire tapped onto that orange/blue wire mentioned above. If there isn't, then your alarm system was not hooked up right.
If you give me details as to what type of aftermarket system you have, then I can probably guide you through a permanent solution without cutting anything.
01GLEMist, I just googled that picture as a quick reference. All information on it is perfectly accurate. I've installed alarm/starters on many maximas before so that's how I know.
Old Oct 21, 2009 | 09:29 AM
H8tank's Avatar
We didn't have an alarm system installed, simply a keyless entry w/remote Start. This problem with alarm going off started before we added this however. The factory keyless entry stopped working a couple years ago, but we didn't have a problem with the alarm going off until recently. It only goes off when you open a door, and only sometimes.
The system is an AUTOPAGE RS-600. We don't live in an area where I need the alarm, I would like to simply disable it. I did not see a fuse labeled alarm...
Old Oct 21, 2009 | 11:45 AM
ReasonableDoubt's Avatar
Your car can be stolen/tampered w/ ANYwhere...
Old Oct 22, 2009 | 09:05 AM
H8tank's Avatar
You can get hit by lightening anywhere, that doesn't keep me from going outside. Besides, the factory alarm is worthless.
Old Oct 22, 2009 | 12:40 PM
TLMNICK's Avatar
The system you have doesn't have to be an alarm to need that orange/blue wire.
Do you ever lock your car without the remote? IF you do, then that is why your stock alarm is arming. If you lock the car using the lock switch, then as soon as you close the door, it'll arm it.
For a SIMPLE solution, you can disable the stock alarm by unbolting the hood sensor. It's a push-button type thing sitting at the driverside headlight on the top of the rad support. Just unbolt it and let it sit inside the engine bay somewhere....but make sure you leave it plugged in. Doing this will prevent the stock alarm from arming, and therefore solve your issues with it going off.
Old Oct 23, 2009 | 11:51 AM
H8tank's Avatar
Excellent! Thank you! Yes, out of habit we do lock the doors sometimes with the door button. I will look for the hood senser and unbolt it.
my03maxima
Jul 28, 2024 07:40 AM
chisam14
Nov 6, 2018 08:56 PM
magiconthetire
Oct 26, 2015 09:03 PM
worldwiderecognized
Sep 30, 2015 01:16 PM
