my second time at the track vids
Old Aug 8, 2009 | 10:50 PM
nzelinsky's Avatar
Check these out- the last race is my buddy in the dodge ram...
http://www.youtube.com/watch?v=Of_EdiaIZOc
I am over 1 mile above sea level.. corrected time is 15.2
Old Aug 8, 2009 | 10:56 PM
HotshotVQ35's Avatar
wow! 16 sec quarter mile times!
Old Aug 9, 2009 | 12:18 AM
nzelinsky's Avatar
ya i know its not very fast... im trying
Old Aug 9, 2009 | 07:09 AM
VQP0WER's Avatar
Yikes, my 3.0 can get better time than that.
Old Aug 9, 2009 | 07:20 AM
User 12822's Avatar
How are you running 16s with an 02?
Old Aug 9, 2009 | 08:05 AM
johnnyd2k2's Avatar
Definatly seems a little slow even my auto with intake and exhaust ran 14.8
Old Aug 9, 2009 | 08:57 AM
Unklejoe's Avatar
What altitude are you at?
Old Aug 9, 2009 | 12:14 PM
nzelinsky's Avatar
1,048 M (3,438 FT)
I dont think taht winter tires are helping me though. I get a bit of wheelspin in 1st and going to 2nd...
Old Aug 9, 2009 | 12:18 PM
perkman87's Avatar
are you gate shifting?
Old Aug 9, 2009 | 01:14 PM
SmokinMax02's Avatar
Corrected times for FRI August 7th in Calgary w/ 5148FT Density altitude:
15.24 E/T
87.47 MPH
15.44 E/T
86.89
Hmm...even after correction though, your times and MPH are still quite low...
Old Aug 9, 2009 | 03:17 PM
Grand_hustle17's Avatar
And who's advice was you following???... if its the cold air injen intake, i say take it off, sell it, and get yourself a good homemade short ram intake
Old Aug 9, 2009 | 03:23 PM
tookrzy4u192's Avatar
what was your 60' ?
Old Aug 9, 2009 | 04:21 PM
nzelinsky's Avatar
60's were 2.77 2.64 2.72 and I was just letting the transmission shift on its own.
hmm I think I can modify the injen to work as a short pipe...
Old Aug 9, 2009 | 05:59 PM
nishfish871's Avatar
No wonder, you need to manual shift it right at 6600. How are you launching? You should be using the power brake then half gas until you loose some of the wheel spin then just floor it. Takes a bit to get it right though.
Old Aug 9, 2009 | 06:23 PM
nzelinsky's Avatar
cool thanks for the tip, ill try that next time
Old Aug 9, 2009 | 06:48 PM
jr schultz's Avatar
I agree. Foot brake to 2000 then full throttle after you roll out a little. A drop resistor mod would help out a lot as well! Easier on the tranny and it shifts faster. Like was said above...manually shifting the auto allows you to get another 500 to 600 rpms out of the gear.
Old Aug 9, 2009 | 06:51 PM
jr schultz's Avatar
Also...Rear tires inflated to almost max psi. front tires down to 20psi.
Old Aug 9, 2009 | 08:03 PM
nzelinsky's Avatar
drop resistor? is that like the trango shift kit?
Old Aug 9, 2009 | 08:04 PM
CMax03's Avatar
Easily!!! I had a 00 Maxima w/16" five spoke wheels and 02-03 front calipers/rotors and they fit really close but they fit!
Part of your problem is your launch...stump on the yellow! Take your MAF/w the adapter, cone filter and your Oem mid pipe and oem resonator and run that instead of the Injen intake (it's too long for 1/4 mile running, it's built for low-mid range rpm). Don't smoke your tires IMO....and power brake from at least 1500 rpm...GL.
Old Aug 9, 2009 | 08:27 PM
yeah get that 60' down and you should be getting better results..
jr schultz's Avatar
Its like a switchable version that's cheaper. The transgo kit modifies the valvebody of the tranny to shift quicker. The drop resistor mod is a switch hooked up to the tranny shock tower resistor. Turn resistor off for fast shifts and back on again for normal shifting. Disabling allows full fluid pressure in the tranny. Many ways to do it...Install a simple switch or a switch under the accelerator pedal that disables the resistor at wot. For the 5th gens it causes a check engine light that I just reset after track use. Look at jime's write up in the nitrous stickies. He swears by the drop mod.
Old Aug 9, 2009 | 10:27 PM
nzelinsky's Avatar
ya i just practiced some shifting on the highway and I think I can get a bit faster holding it in 2nd gear longer
Old Aug 13, 2009 | 06:24 PM
Hind135's Avatar
Time for a turbo!
Old Aug 13, 2009 | 07:02 PM
jasonmax's Avatar
its not a track, its a drag strip.
Old Aug 13, 2009 | 07:06 PM
samething dude
Old Aug 13, 2009 | 07:20 PM
jasonmax's Avatar
samething dude
maximas aint straight machines, so a track for us is where you take corners. if you drive an american muscle, thats another thing.
Old Aug 16, 2009 | 11:25 AM
PatKeo6373's Avatar
our maximas need some bracing for corners. With the front wheel drive we have bad understeer. The maxima is good for a straight line but deff not the best choice on a road course.
Old Aug 16, 2009 | 01:16 PM
User 12822's Avatar
I think theres quite a few people who would disagree with you on here.
Old Sep 5, 2009 | 03:06 PM
maximaTC92's Avatar
pretty brutal dude.
practice makes perfect.
good luck
Old Sep 5, 2009 | 06:47 PM
nzelinsky's Avatar
dragstrip = racetrack
Old Sep 5, 2009 | 06:56 PM
the definition for a closed road coarse (track) is not defined on whether you have an import or domestic... it is a closed road coarse... a track, a nascar ring "track", auto-x "track", drag strip "track" just different kinds of tracks, one a straight line, one a ring, one a curvy road, all in all a track... the reason im conitnuing this whole track thing is because even if it wasnt a track, you know what he was talking about, your post had no significance to the thread and i guess you felt as though it was the most important input to emphasize you personal opinion of a track because i guess u "track"...
Old Sep 5, 2009 | 07:16 PM
guyzndollzco's Avatar
"WOW thats slow!"
Ease up guys.. im sure the guy knows its not record times. So what?
He posted videos for entertainment.. something to check out.
Not to get dogged for slow times.
Thanks for posting the vids
Old Sep 5, 2009 | 07:27 PM
NissanTun3r's Avatar
nice vid...but do not disgrace our cars with such bad times rofl
my stock auto 3.0 ran a 15.8 so you have no excuse
Old Sep 6, 2009 | 07:21 AM
obviously the two previous posters have a problem reading and should get that post count taken away........... if you had any idea about elevation and drag strip you would understand... if he was at ur elevation he would have kicked ur **** because it was calculated by someone on here to be a 15.2 run at regular elevation... i did 15.0 with my auto 2000 with ebay intake and greddy catback, so whats your point??? how does that compare to the OP's runs???
Old Sep 6, 2009 | 07:35 AM
AceofSpds's Avatar
wat
Genius post. Go play in traffic.
Old Sep 6, 2009 | 07:51 AM
CMax03's Avatar
Bottomline, practice on your launch! Concentrate on your sixty foot/RT times and all other times will reduce drastically...20-24 psi in the fronts, let the trans shift on it's own, leave it in 3rd gear....powerbrake @1500 rpm and leave on the last yellow light. My 03 stock best time was a 14.9 sec/1/4 mile and my rt and 60' were horrible. Don't heat your tires either you don't have drag radials...GL
Old Sep 6, 2009 | 07:54 AM
nzelinsky's Avatar
Good job reading the thread buddy...
Just wait guys, my headers and NWP plate are shipped, exhaust is still on back order... these times will improve. Saving up for 75 shots and full kit.
Next spring I will replace winter tires with street and there should be a pretty big launch difference with the increased traction.
Old Sep 6, 2009 | 04:27 PM
Maybe you should've explained that in the first post, I didn't read the whole thread, I read the first post and replied. I don't go through threads and read every post, I have a life thanks. idiot
Old Sep 6, 2009 | 04:29 PM
No problem reading, some of us have a life and girlfriends that look like models that need our attention more than trolling on forums, thanks.
Old Sep 6, 2009 | 06:23 PM
FRZ251's Avatar
Wow yea something is definitly wrong with his car. Bro you E-brake stuck on, I mean 16's my honda odessey did a 16.3 lol.
