clicking sound at 2000 RPMs
Old Aug 10, 2009 | 06:15 PM
Maury's Avatar
My 2002 Maxima has been making an intermittent clicking sound for months now. I've done alot of research, visited dealers and local garages, and today I thought I figured out that it was a low oil problem. I just had an oil change done and it's still happening. Can anyone help me figure out a) what this is and b) whether or not its serious? I'll try and post a sound clip, but it sounds like an old typewriter and almost has the tone of a spray-paint can rattle.
Old Aug 10, 2009 | 06:21 PM
Ghost_54's Avatar
I moved up to 94 octane and this seems to have helped, if the sound you hear is a bit metallic could be have a bit of pinging going on, if you are using regular gas (87 octane) then I would most definitely say you have some pinging.
Old Aug 10, 2009 | 06:27 PM
cmd26's Avatar
its normal for maxxes to make this sound mines been doin it since 05
Maury's Avatar
Thanks but nope, I use 91 or higher all the time.
Old Aug 10, 2009 | 06:31 PM
Maury's Avatar
Really? Do you know what it is?
Old Aug 11, 2009 | 07:58 AM
2damax's Avatar
after the oil change did you check the oil level? Just a thought.
Old Aug 11, 2009 | 08:02 AM
Maury's Avatar
Yes, I checked it now - half a day later- and it reads FULL.
Old Aug 12, 2009 | 11:36 AM
Maury's Avatar
UPDATE
update: a good mechanic friend of mine took my car for a road test and he's pretty convinced its pre-ignition. He thinks my car is knocking from bad gas. I use 91 or higher all the time but oh well. I'll try fuel injector cleaner, a new air filter and new gas as a starting point. Nissan dealer #2 will get to try and diagnose this as opinion #3 tomorrow. Any thoughts would be much appreciated. thank you
Old Aug 13, 2009 | 06:31 AM
Maxgig's Avatar
Maury, keep us updated. My 03 is making the same noise and has been for quite a while. I've used all octanes of gas, oil additives, fuel additives (even though the owners manual says not to) and changed my oil viscosity in an attempt to "fix" the problem. The good news is that the car still drives good, I'm just sick of the rattling noise it makes.
Old Aug 13, 2009 | 07:17 AM
Maury's Avatar
update
update: my mechanic pal recommended i add some fuel injector cleaner to my gas right away, buy different gas next time, and change my air filter. i didn't spend a full tank yet but i did the other 2 suggestions and WOW. i hadn't noticed it before but my car wouldn't redline when i hop on it. it would change gears after only 4000 rpms or so. now, when i floor it, the tach goes all the way to red before it shifts, the car is MUCH more powerful in every gear, and the clicking all but stopped! i still get it to click around 2000 rpms SOMETIMES but not always. also, when cruising at legal speeds 35-55, my rpms are now around 1600. yesterday they were around 1900, so not only does my car make this noise much less often at 2000 rpms, my car is rarely AT 2000 rpms anymore. i'm gonna replace the spark plugs next, since its only 20,000 miles early and i figure anything i can change in this neighborhood of the engine is smart to do. more info on the way. comments/suggestions welcome. btw i cancelled my appt with the dealer this morning since i can't make the car make the clicking on command anymore.
side note: does this mean my local station has been selling bad 93 gas OR selling 87 labeled as 93???
Old Aug 13, 2009 | 08:08 AM
fflint_18's Avatar
Good News.
Did you do the fuel injection cleaner? How bad was the air filter.
If your injectors are that clogged you might want to run another bottle through (I recommend Techron) and see how things progress.
Or spend the money on a good professional injector cleaning.
Old Aug 13, 2009 | 08:13 AM
Maury's Avatar
air cleaner was pretty bad, and MIGHT have had 70k on it. ugh. yeah i'd spring for a pro cleaning if its recommended.
Here's a link to a pic of one of the plugs - all 6 loks the same. dirty and the tips were crusty white.
http://i.b5z.net/i/u/1530927/i/IMG_0371.jpg
Old Aug 13, 2009 | 11:57 AM
Maury's Avatar
I THINK IT'S FIXED
I changed spark plugs (and intake manifold gasket) &air filter, added a can of fuel injector cleaner to my tank, and the initial results are in ... NO MORE CLICKING. I'll post back as soon as I hear the noise return - hopefully that will be never.
For the record, the air filter and gas treatment did 90% of the work. I could only faintly hear the clicking, but it was happening far less often and it was extremely hard to hear. The spark plug swap has now completely erased the noise.
I have to think it was pinging from bad gas and a bad air filter. You guys have anything to ask/add?
BTW my car is now the ROCKET I remember test-driving when I first bought it. Way more power.
Old Aug 13, 2009 | 03:12 PM
pro23's Avatar
good for u!!! happy u got ur car running hard!!!
Old Aug 13, 2009 | 04:44 PM
Maury's Avatar
yeah i'm pretty psyched.
Old Aug 13, 2009 | 06:17 PM
Hind135's Avatar
Belts?
Old Aug 14, 2009 | 03:42 PM
Maury's Avatar
No, we never suspected the belts and none of my mechanics/friends looked in that direction.
Old Aug 17, 2009 | 08:17 PM
03blackSE's Avatar
What brand of fuel injector cleaner did you use? I'm interested in trying this as well...
Old Aug 17, 2009 | 09:51 PM
Maury's Avatar
I added one bottle of the cheap STP injector cleaner to 3/4 of a tank. When that ran out, I did a bottle of Techron and 12 gallons of 93. That tank just ran out tonight and I filled up on 93 with no cleaner added this time. We'll see if (a) my problem is fixed and (b) if I get better gas mileage.
Mar 12, 2020 12:06 AM
alahjahwan09
18
Sep 21, 2015 09:12 PM
ballerchris510
Sep 11, 2015 05:29 PM
bennuss
Sep 11, 2015 05:55 AM
jfl330
Sep 4, 2015 01:44 PM
