View Poll Results: Seafoam yay or nay
Haven't tried it
27
46.55%
YAY Love it
27
46.55%
NO Way - Tried it with bad experience
6.90%
Voters: 58. You may not vote on this poll
Seafoam - yay or nay
I keep reading mixed impressions of the seafoam and I think I am going to give it a try. I just want to get some numbers on opinions for a better comparison.
I like that your "No way!" option is qualified with "Tried it".
It seems most of the naysayers are sounding off on principle, not personal experience.
This should be an interesting poll.
I have not tried the product yet, but there are a number of members here in Toronto that have and have only good tings to say about the products ability to remove unwanted carbon deposit from inside the engine ... I do plan to give the product a try before my next oil change
How is the BG 44K doing for you? Have you given updates yet?
As for seafoam, it will be a while before I try it again.
However, in the last few days the car starts much more smoothly, which is odd. Since installing ES mounts this past spring, the car would start like a bucking bronco. It's not that way anymore. Coincidence?
Did it to my 00 Maxima and it works. Of course there is the smoking part. I swear it looked like my car was on fire with the smoke it was shooting out. The car response alot better and i did see a little improvement on the gas. Change the oil right after using it.
Oh its works for sure! I've been using it for 5 oil changes. I would probably advise you to NOT use too much, I went a little crazy for the first few times and got my fuel filter clogged from too much stuff being cleaned from Seafoam being knocked from the lines and getting stuck in the fuel filter.
Not sure if thats really true but that is what the mechanic said, and so....
- Vikas
I didn't get huge results in the gas tank, but later did the one where you suck it right into the intake, let sit, then rev up and run for a short sprint. A lot of smoke...a LOT of smoke. But it ran better immediately, more response from the pedal and smooth idle. Mileage was up about 2 mpg's on the highway, and about the same around the city.
This was on my 07 with about 23000 miles on it. I didn't think 23k was enough to have that kind of buildup, but alas it needed a cleaning.
220k+ A32
09-23-2015 03:38 PM
