Water in Catch Can
Water in Catch Can
My oil catch can seems to be collecting dirty water instead of oil. The oil on my dip stick is fine. I haven't changed the oil to see what it looks like.
Any ideas what could be causing the water in the catch can?
well the product of combustion is carbon dioxide and water
I would think it's simple water vapors especially if your in a high humid region of the country. Since air is drawn into the engine's (PCV system) and thru it. I'm sure it's simply humidity...
There is an extremely far out chance that your headgaskets are bad and coolant is getting into the crank case and then evaporating when you run the engine causing the water vapors to come out through the PCV valve.
Im not even sure that that's possible though.
there are so many varying factors that it's hard tell the reason unless the mixture is tested.
RWCreative
Sep 21, 2015 11:01 AM
