Power Steering fluid leak. Please Help?
Old Aug 17, 2009 | 12:20 PM
nismax96's Avatar
For the past couple of months I've noticed a small loss of power steering fluid, but in the past week it has gotten worse. I have put at least 2 bottles of fluid in this past week. I have looked on the ground and it looks like as soon as the car is parked all fluid leaves the reservoir. Could this be the pump or hoses causing this problem? I have also noticed a leak coming from the hose near the fire wall on the passenger side. (Sorry couldn't find a picture)
Thanks for your help.
When I originally did the search on this i didn't notice the thread from another org member. I have since read the thread and see what the issue is. Sorry for the repost.
Old Aug 17, 2009 | 01:27 PM
mymaxi41691's Avatar
i've had this same problem. It was the lower hose. left some nasty stains in my driveway too =/ but it cost about 70 bucks to reapir.
Old May 6, 2010 | 09:50 PM
Tripower's Avatar
Is the lower hose the one that runs from the borrom of the reervoir (closest to firewall) to the PS pump? Thanks.
Old May 7, 2010 | 09:29 AM
DOHCtorJT's Avatar
Check the upper "high" pressure hose. This one bolts to the firewall, and there is a foam insulating sleeve around it. Pull this foam back and see if it's wet, if it is, you'll need $140 and a couple hours of free time. There are other threads on the install/replacement of this hose.
Old Jul 18, 2010 | 06:57 PM
Mizeree_X's Avatar
Getting back to his roots
Do you generally replace the reservoir when you replace the hose(s)? This was standard procedure on my bimmer, but German plastics tend to be more brittle than Japanese ones, at least from my limited observations.
Old Jul 18, 2010 | 08:05 PM
MoeBelikeMax's Avatar
im having the same problem right now ....can someone please give me the link on how to change the upper "high" pressure hose
Old Jul 19, 2010 | 10:18 AM
jasonmax's Avatar
you disconnect it then put the new one in?
Old Jul 20, 2010 | 09:15 AM
mandyfig's Avatar
Had the same issue on mine, replaced the high pressure hose and now, almost no leak. Cost $300+. I also added a conditioner-leak preventer on the power steering fluid, stopped the slight weeping of fluid on connectors. Keeping fingers crossed.
Old Jul 20, 2010 | 09:37 AM
f.weezy.babii's Avatar
same issue had to get a new hose.. cost no more than 300 includin parts and labor.. i have my own mechanic
Old Jul 20, 2010 | 10:49 AM
zero2sixtyZ's Avatar
You embarrass me.
high pressure hose. right near the firewall. mine is leaking as we speak.
http://forums.maxima.org/5th-generat...hose-02-a.html
Old Jul 20, 2010 | 02:35 PM
Thanks Guys
Old Jul 20, 2010 | 03:22 PM
SoonerFan's Avatar
Cletus
agreed...thats where my leak was from
Old Dec 4, 2010 | 05:59 AM
rodriguo's Avatar
Guys,
A few months back I had to replace the high pressure side hose on my power steering pump. I ended up topping of the reservoir with power steering fluid, instead of ATF fluid. So know I have this brown pasty (oily) substance leaking from somewhere the steering pump.. Any suggestions on what I need to do to fix in addition to just replacing the pump and flushing the fluid? Thanks
P.S I have pictures but can not post them due to newbie limitations
Old Dec 4, 2010 | 10:30 AM
DennisMik's Avatar
Adding power steering fluid instead of ATF should not have caused a leak. It may be unfortunate timing that the 2 things happened so close in time.
Photos would be nice... can't you just type the link in? I don't know exactly what restrictions newbies have.
lowpost99
Oct 26, 2025 06:53 PM
captchaos
Mar 15, 2016 12:18 PM
2kmaximel
Sep 10, 2015 08:13 AM
SusieQQ
Sep 9, 2015 12:14 PM
trungg86
Sep 4, 2015 04:58 AM
