Wheel hopping
Old Aug 19, 2009 | 11:56 PM
jasonmax's Avatar
Wheel hopping
anyone has experienced wheel hopping under hard acceleration on maximas?
my maxima does that sometimes quick off the line, the front wheels jump and make noise like going over pot holes, car shakes too.
I heard it can be bad for the axles and tranny. is it because my struts are slightly old?
this is what it looks like, not that severe, but you got the idea
http://www.youtube.com/watch?v=DHlEWHJ-o2w
http://www.youtube.com/watch?v=sARgbCkjX4U
Old Aug 20, 2009 | 06:40 AM
asianstyle's Avatar
I have the same problem but mine did it before I changed my struts and still did it after I got new ones. I changed my endlinks and that helped just a tad but it still does it. I'm not sure how to fix this problem.
Old Aug 20, 2009 | 06:44 AM
321VQ35MAX's Avatar
NWP makes something that might help.....
Old Aug 20, 2009 | 06:49 AM
asianstyle's Avatar
do you have a link or anything?
Old Aug 20, 2009 | 06:50 AM
321VQ35MAX's Avatar
http://forums.maxima.org/group-deals...now-stock.html
Old Aug 20, 2009 | 07:02 AM
321VQ35MAX's Avatar
I am going to purchase this soon, any a few people have bought it and like the product. Aaron makes great products..
Old Aug 20, 2009 | 07:16 AM
asianstyle's Avatar
that's good stuff, i'm gonna get one also when I save up some more money. thanks for the info.
Old Aug 20, 2009 | 08:30 AM
Rochester's Avatar
There are a number of contributing factors; (struts, springs, mounts, tires, temperature, added horsepower over stock, etc.)
However, it's likely your motor mounts are old and squishy, allowing the engine to lift too much under load.
I had horrible wheel-hop as well. Installed ES Motor-mount Bushings.
No more hop. Much improved performance.
Old Aug 20, 2009 | 08:32 AM
knight_yyz's Avatar
Toolie
replace your engine mounts with urethane, and replace the crossmember bushings with urethane as well.
Old Aug 20, 2009 | 08:41 AM
321VQ35MAX's Avatar
Good point. I forgot about the mount inserts.... I did mine along with the subframe bushings. It did make some diffference. Still have some wheel hop, but not nearly what I did...
Old Aug 20, 2009 | 08:48 AM
Staticxout2's Avatar
I bought the torque link kit from Aaron @ Maxus, and I love it! highly recommend it for any wheel hop issues.
Old Aug 20, 2009 | 10:48 AM
DrunkieTheBear's Avatar
Turbo'd Saab
I was investigating a way to eliminate this. Some other forums with a similar setup have guys taking the two front bolts out the of the cross member and putting 2-4 washers to space the crossmember from the frame. This in turn brings the engine forward helping to reduce wheel hop.
Someone may want to try this
Old Aug 20, 2009 | 05:28 PM
CMax03's Avatar
I installed the front and rear ES motor mount poly bushings and the subframe bushings, adjusted my struts to (5) front/rear and it grips with no drama now still wish I had LSD in my A/T TE 2003! But once it cools down, I should be ableto perform 60' launches under 2.0 seconds! I was already down to 2.171!
coolsun
Wheels/Tires
Oct 15, 2015 10:52 PM
Cipitiox
Wheels/Tires
Sep 30, 2015 06:16 PM
Andy29
Sep 29, 2015 05:32 AM
Garrettz459
Sep 28, 2015 02:50 PM
Redfox
Sep 28, 2015 10:41 AM
