Do I need a rear camber kit?
Old Aug 22, 2009 | 06:30 PM
seeker's Avatar
Hey guys, I ordered Ksport coilovers and I had a quick question.
Coilovers I ordered:
http://www.raceinspired.com/ps-15084...2000-2003.aspx
My friend who is a mechanic said you can adjust front camber with the coilovers but I need to order a rear camber kit. Is this true? Ive been trying to find one and all I can find is a kit for the front. I dont know anything about adjusting camber... Never learned it. If someone could help me with this that would be great.
Old Aug 22, 2009 | 06:45 PM
n3985's Avatar
大陆弟弟
5th gen rear suspension is non-adjustable.
Old Aug 22, 2009 | 06:47 PM
seeker's Avatar
Thank you very much. So Ill just have to live with the uneven tire wear? lol
Old Aug 22, 2009 | 06:49 PM
n3985's Avatar
大陆弟弟
The alignment in the rear should be in spec unless it's been hit, and if it was hit hard enough the repair shop would have pulled the frame back to spec. In summary, just install the COs and enjoy.
Old Aug 22, 2009 | 06:51 PM
seeker's Avatar
Ok. I appreciate it.
Old Aug 23, 2009 | 02:49 AM
Turbonut's Avatar
Just so you know, it's a solid rear axle so no adjustment can be made. If it were an independent rear suspension, most don't have built in camber adjustments from the factory, only toe, but aftermarket camber kits can be purchased and installed so camber can be adjusted.
Old Aug 23, 2009 | 06:23 AM
seeker's Avatar
Oh alright, Where can I purchase a rear camber kit?
Old Aug 23, 2009 | 07:47 AM
DrunkieTheBear's Avatar
Turbo'd Saab
you can gain rear camber actually....a couple guys talked about doing this in an autox thread. Bending the rear beam purposely to create rear camber although the bad part is its not reversible.
Old Aug 23, 2009 | 08:22 AM
Turbonut's Avatar
This is correct as some like the look of the slanted tires, or for handling on road courses, but normally, with the stock rear suspension and being a DD, the toe/camber/wheel position should not be out of specs unless worn parts or damage from an accident.
Old Aug 23, 2009 | 10:20 AM
anomaly117's Avatar
you dont need a rear camber kit. rear susp. is a dead axle; the camber doesn't change when you lower it.
matts95max
Apr 23, 2025 10:44 AM
AcuraLegend
Oct 17, 2016 08:47 PM
AcuraLegend
Sep 22, 2015 04:22 PM
doctorpullit
Sep 10, 2015 06:33 PM
A32goldylocks
Sep 2, 2015 06:39 AM
