Headlights went out
Old Aug 24, 2009 | 07:37 PM
YoungLee's Avatar
Headlights went out
My headlights went out, brights still work. Overwhelmed with info. I heard I its a dealer part so I have to get it through the dealer. Does the 5.5 come with hids stock? Should I just buy new headlights? I like angel eyes, just dont know anything about them.
Old Aug 24, 2009 | 07:54 PM
03VQMAX's Avatar
The 5.5 headlamp does come with stock xenon lights.
Old Aug 24, 2009 | 08:01 PM
The6spdMax's Avatar
Its stock HID, and expensive to replace.
Old Aug 24, 2009 | 10:26 PM
Tee00Max's Avatar
your probably better off going to an aftermarket HID kit....The nissan xenon kit is gonna cost a pretty penny.
Old Aug 24, 2009 | 11:11 PM
YoungLee's Avatar
What do you recommend? Are ebay headlights garbage?
Old Aug 24, 2009 | 11:22 PM
unrealii's Avatar
Both headlamps went out?? What diagnostics have you done? Have you checked your fuses? Look at the FSM link in my signature and go through the headlamp diagnostics.
Old Aug 24, 2009 | 11:25 PM
YoungLee's Avatar
Theyve been out since I bought the car. I didnt notice until the night after I bought it. The dealer didnt want anything to do with it...
Ill check the link
Old Aug 25, 2009 | 09:16 AM
Jmahad01's Avatar
Ill check the link
Did you buy the car from the dealer? If so then they can not sell you a car without working headlights as it is obviously a safety issue and they would have to take care of the problem or have a big lawsuit on hand. If you bought it through a private party then your going the right step looking at alternatives. Too bad you didnt check them out before you bought.
Old Aug 25, 2009 | 09:23 AM
jasonmax's Avatar
I thought hids never die
Old Aug 25, 2009 | 09:52 AM
maximase86's Avatar
I love lamp.
Uh they can die just like any light bulb.
S
Old Aug 25, 2009 | 10:00 AM
YoungLee's Avatar
I bought it through a dealer.
So what should I get?
Old Aug 25, 2009 | 10:55 AM
Jmahad01's Avatar
Take it back to them and tell them they cannot sell you a car that wont pass inspection and to fix the problem. How long ago did you but it? 30-90 day warranty?
Old Aug 25, 2009 | 09:05 PM
YoungLee's Avatar
I bought it late june. I have a 12 month warranty through a different company that also blows. I told the manager they lights were out and you gave me the your bad you didnt notice before you bought it look. I try not to deal with them anymore, im paying the bank, the managers a pansy i almost made him do something about it the old fashioned way.
Old Sep 2, 2009 | 06:32 PM
YoungLee's Avatar
The pdfs looks like theyre written in chinese to me
Old Sep 3, 2009 | 05:44 AM
queenambeach's Avatar
If it's both light, then check to make sure a fuse of some sort isn't blown. This might sound stupid, but check to make sure you even have ballast and/or D2R bulbs in the headlamps. If not, then get a HID kit on ebay for the ballast and OEM D2R bulbs. You'll need some adapters.
Old Sep 7, 2009 | 06:15 PM
Andypot1985's Avatar
my right side bulb just blew out. are they hard to replace? anyone know what bulb it is?
Old Sep 7, 2009 | 06:53 PM
CMax03's Avatar
Got a lawyer? Have the lawyer give the dealer( owner/president) a courtesy call...I guarantee they will fix it then...As someone else stated it has to pass the state safety inspection to leave a dealership lot!
But in the mean time check you fuses and and relays, and make sure the ballast are actually connected with the connector..if so check you HID bulb plug for power...Be careful! No way both headlights went bad at the sametime!
Old Sep 10, 2009 | 10:55 PM
YoungLee's Avatar
Please dont laugh, but how do I check the fuses and relays? Ballast? How do I check the HID bulb plug for power? I know my age is showing, but ive never had to do this **** before and I wanna diy and save some money.
For instance, Im looking at the CONSULT-II inspection procedure. It says connect "CONSULT-II" and the "CONSULT-II CONVERTER" to the data link connector. This has me confused, is this something that is separate from the max used to read codes/diagnose the problem?
From what I understand, since neither headlamp low beam operates, it could be a 10A fuse, Lighting Switch, or smart entrance control unit. To determine if its a 10A fuse, Im supposed to check 10A fuse, and verify battery positive voltage is present at terminal 49 of smart entrance control unit. Again, how do I do this? I dont even know where this is. To determine if its the Lighting Switch, Im supposed to check the Lighting Switch, then to determine if its the smart entrance control unit, check the smart ECU. Should I disconnect the battery before doing this? Am I right that these three possible causes are the only possible causes, besides dead hids? This is probably easier than Im making it out to be, but Im a noob whos never had to diy before.
Old Sep 10, 2009 | 11:36 PM
unrealii's Avatar
Start with the basics:
Check fuses
Check relays
Check to that bulbs are connected
Look for damage to wiring
Use a multimeter to probe the wires and make sure +12v and ground power is connected
Use the service manual to understand the schematic of the headlights. These are all simple tasks which you can google to find assistance on how to carry out. If these are too difficult, you are better off paying a mechanic or bribing a local org'er with beer.
doctorpullit
Oct 28, 2019 10:58 PM
trsandrew
Apr 8, 2016 06:45 PM
knight_yyz
Nov 1, 2015 01:34 PM
trsandrew
Oct 25, 2015 02:47 PM
Noela
Sep 26, 2015 08:22 AM
