vias block plate, intake and throttle body spacers questions
Old Sep 10, 2009 | 02:14 PM
nismo2ner's Avatar
down with Bing
I will be changing my plugs before winter and would like to do these mods.
My biggest question is at work I can make all kinds of stuff in aluminum or steel. So.... Could I make any of these things myself?
Ive been searching around on here about gains and pros and cons of these mods and will probley do it when I do the plugs. But the block plate looks VERY easy to make and im sure I could do the throttle body spacer as well. The one i would not tackle is the intake spacers. So if I would do this
Could i just make the block plate and the throttle body spacer and be done, not do the intake. Is this ok to do? What will the pros and cons be.
02 se mt6... mods... Custom or homemade intake and greddy catback
Thanks for the help everyone!
Old Sep 10, 2009 | 02:36 PM
sureal00's Avatar
block plate should be the easiest to make its just really a custom cutout plate
Old Sep 10, 2009 | 02:53 PM
nismo2ner's Avatar
down with Bing
ok. so all i really have to do is make that and put it on? I can follow the instructions from the NWP site.
Thanks anyone else have any input
Old Sep 10, 2009 | 03:28 PM
nzelinsky's Avatar
dont be such a cheapskate. The guys at NWP have tested thier products and they work. If you homedepot your own thats just ghetto. Maybe you could start a new mod though... GBP mod and GTBS mod... ftl those things arent even expensive...
Old Sep 10, 2009 | 03:53 PM
nismo2ner's Avatar
down with Bing
But y pay for it when i can just take the drawing to work and program it into the cnc and its done. It may not be exact but we can hold our tolerance to about 2 thousands so I am not worried about fitment issues just pros and cons to the car and performance.
Old Sep 10, 2009 | 07:20 PM
Wheelie King's Avatar
Do it yourself, have fun, and save your money for a mod you can't do yourself. The plate should be easy. I know a guy who made one out of clear plexiglass. It looked cool and worked alright but wasn't rigid enough. I pulled mine, cut the butterfly valve off with a hacksaw and vice, plugged the hole with a $1 bolt and called it a day. It took an hour. You can do better.
I bought the spacers and they seem to add power. I felt an improvement. I'm not so sure how much power gain can be attributed to cooling the intake vs. increasing the volume of air in the system. The intake gets pretty hot despite the spacers. Maybe you could gain power with aluminum spacers. You'll need longer bolts though and you don't want to strip anything.
Good luck.
Old Sep 10, 2009 | 07:42 PM
mist max2000's Avatar
the guys at NwP have alot of R and D into their products that they design for us, so dont expect to cut out some spacers reguardless of your current technology available to you that perform and dont leak, now the block off plate.. sure..take the old one off to give you the demensions with the bolt pattern and there ya go..machine it up...on a side note..the manifold spacer IMHO is the most important one.. the main thing they do is reduce the manifold temp's thus reducing the air temp into the engine.. and well .. the rest is horsepower
Old Sep 10, 2009 | 07:46 PM
nismo2ner's Avatar
down with Bing
Good luck.
ok thanks! I was thinking alum. would be better for dispensing heat maybe i will go that way.
Old Sep 10, 2009 | 08:00 PM
Stormzusmc's Avatar
my buddy owns a water jet machine and can make both, but i just got the nwp stuff
Old Sep 10, 2009 | 08:25 PM
Gemner's Avatar
aluminum spacers and phenolic spacers are two totally different things. dont expect to get any change in temperature with aluminum, thats what the manifold is made from already. the VIAS block off plate though you ought to do yourself, i made my own and happily spent the savings on the spacers set
Old Sep 10, 2009 | 10:07 PM
Stormzusmc's Avatar
a plastic composite is the way to go
Old Sep 11, 2009 | 01:49 AM
knight_yyz's Avatar
Toolie
just make this, buy the phenolic spacers
Old Sep 11, 2009 | 04:27 PM
nismo2ner's Avatar
down with Bing
ok thanks for all the input!! I think i am going to make the plate and buy the spacers.
I guess my next question is can i run with just the plate and no spacers? pros and cons of this.
And does anyone have a write up the plate installation and what i have to cut out. Just want to make sure i have a good understanding of what i am about to do here.
Again thanks for the help
Old Sep 11, 2009 | 04:48 PM
SteveB123's Avatar
Keep thinking.
The whole thing is already made of aluminum!
Old Sep 11, 2009 | 04:55 PM
Grand_hustle17's Avatar
did you make that??? if you did thats some good looking work... i agree, you can make the block off plate... but to the OP, seeing that its $40 you should just save yourself the hassle... i like to do things myself too and i consider myself cheap due to my budget but both the block plate and spacers i would definately buy from aaron... great guy and great products
Old Sep 11, 2009 | 09:54 PM
Scottwax's Avatar
That's Mr. Detail to you
According to a dyno sheet I've seen of an Altima with just the block off plate, there was a 10 hp drop between 2800-3800 rpms and 10-12 hp gain from 3800 rpm to redline. Under 2800 rpm, there was no change.
I believe NWP has the installation for their VIAS block off plate on their website.
Old Sep 12, 2009 | 05:50 AM
nismo2ner's Avatar
down with Bing
Yeah i saw that, but i was reading on here that you have to cut butterflies out and a little shelf in there or am i confused with something else?
Old Sep 12, 2009 | 07:17 AM
knight_yyz's Avatar
Toolie
yes I made that plate, I didn't see the point of paying someone a huge amount of money for a fancy shiny plate to stick on my dull pitted ****ty japanese aluminum intake. Took me about 15 minutes to make it. I started polishing it then realized it was a dumb idea. When I am ready to install it I will drop it in a bucket with some deanodizer to give it the same finish as the manifold
vingodine
45
May 21, 2016 12:46 PM
iflexsteel
Sep 15, 2015 03:37 AM
homewrecker
Aug 24, 2015 08:56 PM
Samedi
Aug 13, 2015 04:05 PM
