HELP SES light
Old Sep 10, 2009 | 05:51 PM
KiNgJaMEs's Avatar
HELP SES light
Current mods:
OBX-R headers w/ O2 sim
NWP spacers
Block off plate
Tsundo 2.5" catback
17* Adv timing
I ONLY RUN PREMIUM
Now I have codes
P0138
P0158
P0420
What should I do?? I suspect that my cat is clogged or close is that my prob??
If i straight pipe? Gut the cat? what would it sound like?? I have all aftermarket exhaust except my axle back is stock.
Old Sep 13, 2009 | 06:22 PM
KiNgJaMEs's Avatar
So no one has any suggestions??
Old Sep 13, 2009 | 06:48 PM
Ghost_54's Avatar
I would suspect the PreCat is the problem, a bit surprised to see the two O2 rear sensor code considering they are simulated ... however the P0420 is pointing to a problem with the Precat Catalyst system below threshold. You could go with a test pipe in place of the PreCat but I believe it will be very loud
Old Sep 13, 2009 | 07:13 PM
Ghost_54's Avatar
In reading about your current issue, some have suggested spark plug replacement (when were yours last changed?) as well as adding a fuel injector cleaner on your next full tank fill up to clean up any gumming up of the injectors ... just a couple of other idea's to help
Old Sep 13, 2009 | 09:28 PM
SuperStasiu's Avatar
P0138 - Heated Oxygen Sensor 2 Circuit High Voltage (Bank 1).
P0158 - Heated Oxygen Sensor 2 Circuit High Voltage (Bank 2)
P0420 - Catalyst System Efficiency Below Threshold (Bank 1)
Your first two codes are heater codes which the simulator you say you have installed doesnt simulate so you need to wire a resistor into each one of your heater wires from the secondary o2's. The PO420 could be do to a bad primary o2 sensor or could be that your simulator is wired wrong
Old Sep 13, 2009 | 09:32 PM
blktalon456's Avatar
Just gut the cat or straight pipe it. I don't think it will sound bad as you have a factory muffler.
Old Sep 14, 2009 | 05:14 AM
KiNgJaMEs's Avatar
just replaced plug about 5k ago
Old Sep 14, 2009 | 01:24 PM
Col Ronson's Avatar
This is such horrible advice. Don't add a fuel injector cleaner to your gas tank. read these forums everyone has had bad experience doing them. I put a bottle of techron into my old honda civic and it started knocking for 3 weeks.
Old Sep 14, 2009 | 04:06 PM
Grand_hustle17's Avatar
hopefully you get the issue fixed man, lemme ask... sensor 2 is secondaries right???
Old Sep 14, 2009 | 05:07 PM
Old Sep 14, 2009 | 05:13 PM
soooooooooooooooooooooooooooooo they are the secondaries right???... nvmd i got the answer... i've got a question also... wouldnt the reason for the P0420 code be because of the P0138 and the o2 isnt detecting the cat??? so fixing P0138 takes care of P0420??? just curious...
Old Sep 14, 2009 | 05:15 PM
i would say yes
Old Sep 14, 2009 | 05:32 PM
knowledge lol
Old Sep 14, 2009 | 05:51 PM
KiNgJaMEs's Avatar
IGHT so what is the fix replacement?? or space the O2?? and which ones are simulated by my 02 sim??
Old Sep 14, 2009 | 06:07 PM
should be both secondaries... u fix those, could be ya o2 sim gone bad idk... but you fix the two primaries and my guess is that it will most likely take care of the cat code...
fastcarny
Oct 6, 2015 10:42 AM
DarjeelingRose
Sep 15, 2015 01:20 AM
Maxie40
Sep 14, 2015 11:28 AM
-ReLLiK-
Sep 8, 2015 12:02 PM
Maxima30
Sep 7, 2015 06:13 PM
