vafc help !!
Old Sep 11, 2009 | 05:57 PM
Phantom-V's Avatar
vafc help !!
I installed my vafc II yesterday. I got it used so I just splised the wires and wraped the wires onto the ECU wires. Of course cutting the MAF wire and all the good stuff. Splitting the wires that needed to be 1cm apart also following the thread on here.
Now my car when I hit the gas hard hesitates. Why? Then it will get up and go. Do I need to get pins to hook the wires on or does just wraping them on ok? Throttle is reading on the vafc and all. Did I do something wrong? Its set to 6, up arrow and 1.
Old Sep 11, 2009 | 06:06 PM
vastmax's Avatar
did you mess with the map at all? read through sr20den's thread, he did a very good write up
Old Sep 11, 2009 | 06:16 PM
Phantom-V's Avatar
That's how I did it..from his thread. I'm at a loss. Its fine off the vafc...sigh
Old Sep 12, 2009 | 08:10 PM
Puppetmaster's Avatar
I went through the exact same thing with my VAFC-II, actually, two of them. I never resolved it but it must have had something to do with the harness connection, either the MAF connection or TPS connection (I used the APPS instead of TPS). Are you using pin 73 or 83 for the TPS?
My sensor voltages all checked out fine and the units were set to 0 correction, re-initialized, everything but had the same symptoms. The one thing I didn't change was the harness, which I should have tried to re-install. I even sent one of the VAFC-IIs to Deckdout2 to check and it worked fine on his car.
All the best getting it worked out.
Old Sep 12, 2009 | 08:13 PM
When I had my VAFC-II issues, Matt was actually in town on business and was kind enough to spend a couple hours with me trying to fix it, but we didn't have enough time to get some good data logging done to isolate the issue.
Old Sep 12, 2009 | 10:38 PM
Phantom-V's Avatar
i am using 83. should i change it to 73 just to see the outcome?
and did you ever find out how to solve this problem? im going to try 73 later this sunday. if that fails, what other route did you guys go to get yours to work?
Old Sep 12, 2009 | 10:58 PM
shadyonedeath's Avatar
did you connect knock sensor wire? if so, remove it.
also, put sensors to 04 04 in settings.
And by "wrap", did you just twist the wires onto the ecu wires? I would use splice connectors...
Old Sep 13, 2009 | 07:37 AM
Phantom-V's Avatar
i did put the knock sensor...i will try this also today. this is very helpful.
Old Sep 13, 2009 | 09:51 AM
Phantom-V's Avatar
so i took off the knock sensor and now the VAFC-II works just fine. Will it be reading off now that the knock sensor is off? car feels fine to me.
Old Sep 13, 2009 | 11:23 AM
Child_uv_KoRn's Avatar
Bad *** Newb
I didn't even know you were supposed to hook it up lol
No point, really.
Old Sep 13, 2009 | 12:14 PM
Grand_hustle17's Avatar
i know who is installing my VAFC when i get it
Old Sep 13, 2009 | 12:27 PM
Phantom-V's Avatar
won't be a problem bro.
Old Sep 13, 2009 | 02:54 PM
good ish good ish lol
Old Sep 14, 2009 | 02:58 AM
So its fixed?
have fun
Old Sep 14, 2009 | 07:42 AM
Phantom-V's Avatar
So its fixed?
have fun
yeah, should have noticed that when the person who i got it from had the knock sensor wire (purple wire) tied down out of the way...
thanks for the input
Old Sep 14, 2009 | 03:49 PM
sc0tty8's Avatar
Aren't these things used for tuning? Any type of gains on a stock motor?
Old Sep 14, 2009 | 03:50 PM
^^^ yes, in best answers......... u can get terribly flamed for that
litch
123
Jan 4, 2024 07:01 PM
BkGreen97
Apr 2, 2016 05:47 AM
t6378tp
Aug 24, 2015 07:03 AM
SR20DEN
May 19, 2011 11:55 PM
95maxrider
Jun 30, 2010 01:24 PM
