Brightened My Gauges
Old Sep 18, 2009 | 12:09 PM
jowo9's Avatar
Ok, so I got this idea from metalmaxima. What he did was replace all of the tiny #74 bulbs in his gauges with bigger #194 bulbs. He used some hyperwhite ones and removed the blue filter inside. This is how we made the #194's fit:
http://www.cardomain.com/ride/758364/2
and here is what I did:
I just put in regular #194 bulbs and didn't remove the blue filter. (less risky, easier, less time consuming ) but still brighter (if not quite as white as what metalmaxima did) The gauges are still like 2wice as bright as they were before, which is really what I was going for, as the stock gauges are extremely dim. So here's a pic of my results: (in person, the light appears more uniformly distributed)
What do you guys think? and has anyone else brightened their gauges in any other ways? post pics!
Old Sep 18, 2009 | 01:02 PM
BigOgre's Avatar
man that looks great.. I wanna do that to mine but i dont have the stones to take the cluster apart.. lol
Old Sep 18, 2009 | 03:09 PM
jowo9's Avatar
This was actually super easy to do, and only requires unsnapping the back plastic cover. You don't actually have to take it apart unless you sand the blue filter. I didn't do that.
Old Sep 18, 2009 | 06:21 PM
bigpopaj369's Avatar
looks great! wow another mad cheap easy to do mod yess!! lol,ya it is super easy to take apart nothing difficult about it at all
Old Sep 19, 2009 | 12:03 PM
mist max2000's Avatar
are these 194 LED's? or reg bulbs? sorry for the confusion... also.. do you know approx how many bulbs this consisted of? thanks..
Old Sep 19, 2009 | 05:35 PM
CMax03's Avatar
Really nice guy!
Old Sep 19, 2009 | 05:46 PM
knight_yyz's Avatar
Toolie
there are only 4 bulbs lighting up our cluster (02/03)
Old Sep 20, 2009 | 01:49 PM
jowo9's Avatar
I just used regular bulbs... not LED... buuut... as good as this looks, i think it gets too hot. So i'm ordering a large amount of white LEDs. I'm going to do a real conversion in the next couple weeks. I'll probably do a write-up with pics and start a thread... can't wait!
Old Sep 21, 2009 | 06:43 PM
lookin forward to the write up... too hot as in..scarred about a potential fire hot? lol..
Old Sep 21, 2009 | 07:04 PM
avciugroar's Avatar
I'm curious about that too... I'm scared to do any kind of wiring mod (even the fog light mod) after I caught my sentra on fire three years ago by installing aftermarket fog lights....
Old Sep 21, 2009 | 07:22 PM
jowo9's Avatar
Yeah, well I could smell burning plastic! so i thought I'd better be safe than sorry. Plus, if I do a complete LED conversion it'll look better anyway My plan is white LED faces with blue needles. I'll do a full How-to as long as everything goes smoothly haha... I ordered like 200 LEDs so I'd have a ton to work with. Just waiting for them to arrive... then I'll attempt the awesomeness!
Old Sep 21, 2009 | 07:24 PM
avciugroar's Avatar
I would attempt to follow your how-to if it works out, but I'd rather have someone more experienced perform this kind of surgery. I'd hate to nick an artery...
If it works out, can your services be bought?
Old Sep 21, 2009 | 07:34 PM
jowo9's Avatar
That depends how much they're bought for
haha, umm, just PM me after you see the write-up/how-to that I do and I'll let you know. At this point I'm willing to do it, but I need to see how hard it is etc... k?
Old Sep 21, 2009 | 07:36 PM
avciugroar's Avatar
You got it!
Old Sep 21, 2009 | 08:40 PM
Kquezada28's Avatar
awesome awesome...i wish i had your time....these mods are different
Old Sep 21, 2009 | 10:01 PM
jowo9's Avatar
haha, my time??! I've done these mods over the last year! It's not like I live in my parents' basement and do nothing but put blue LEDs in my car hahaha.
Old Sep 22, 2009 | 06:58 AM
knight_yyz's Avatar
Toolie
to do the cluster you need 4 leds, 2 resistors and a bit of wire. I have a writeup done on another site, but if I link you there you have to sign up. I'll see if I can cut and paste it.
Old Sep 22, 2009 | 07:00 AM
knight_yyz's Avatar
Toolie
What you will need:
soldering iron and solder, electrical tape or shrink wrap. A few feet of 18 or 20 gauge wire, preferably 3 colours to differentiate between +ve and -ve.
4 led's for the cluster lights, 2 more if you want to do the signals.
NOTE: The 02-03 gauge cluster has a blue film on it. Most people think the cluster looks green. That is because the oem filament bulbs give off a yellow hue. Yellow bulb and blue film will give you green. If you want blue, use white LED's. If you want red get the brightest red possible. I know red works, but don't forget that red + blue = purple.
I suggest you get these LED"S http://cgi.ebay.com/10PC-0-5W-StrawH...3286.m20.l1116
Note, before you solder anything you must use a process called tinning. Always dip the end of the wire in the flux, add heat then a bit of solder. Same with the pins, add a drop of flux, then heat then a drop of solder. It makes life much easier.
Ok, step one is to remove the cluster from the car. Bring it into the house and place it on a nice work area.
We need to do some calculations... We all know that to run an LED on a 14V system we will need to add the appropriate resistor. In order to do that we need some information about the LED. The link I posted has everything you need.
We need to know the DC forward Voltage and the DC forward Current.
In this case DC Forward voltage is 3.0V and the forward current is 100ma.
If we go online tothis web site you punch in the numbers.
Source voltage is 14V (14.4 is more accurate)(you will only put out about 13.something volts. But that is ok it will help protect the leds if you guess the voltage too high)
DC V is 3
DC current is 100
4 leds in the array...
and voila, we need a 20 Ohm resistor rated at 1/2 watt. This can be bought at a local electronic shop.
Old Sep 22, 2009 | 07:03 AM
knight_yyz's Avatar
Toolie
Ok so we have a complicated circuit now. To make the circuit a little easier i suggest making 2 circuits with 2 leds. This will change the resistor size, and we will need two instead. So with the new array being only 2 LED's we get the following information.
80 ohms at 1 watt. So buy two of those.
Now we can figure out where we need to solder. Some people prefer to tap right into the harness. I will tell you right now it is a PITA to do that. Trying to splice into a wire in a harness is not easy. fortunately the nissan gauge has small metal pins which we can solder to directly.
We are going to use the following pins.
#64 is the +ve for the cluster bulbs, and #20 is the -ve or ground.
Tin this pin. (#64) That is place a small drop of flux on the pin, then heat it with the soldering iron and add a small amount of solder. Then tin the end of a piece of red wire and solder it to the pin.
Do the same to this pin, but use a black wire
avciugroar's Avatar
Originally Posted by knight_yyz
What you will need:
DC V is 3
DC current is 100
Wonder what it would look like if I did my gauges red with a red needle... I dont know if that would look good
Old Sep 22, 2009 | 07:06 AM
knight_yyz's Avatar
Toolie
On an LED there is a short leg and a long leg. The shorter leg is negative and the long leg is positive. I usually solder the resistor directly to the LED. Use shrink wrap to protect the legs after you solder your wires. You will be making two circuits. Choose how you want to do it. Make the two left bulbs one circuit, or the the two top. Whatever floats your boat. The resistor can go on the negative or the postive lead. Doesn't matter as long as it is in the circuit.
Now you just have to make the circuit. Power source is pin 64. so to the end of that red wire we solder the resistor. Tin both ends, you can cut the legs a little shorter if you like. Then solder to the longer end of the 1st led. Make sure it can reach the socket it will be sitting in. You may need to add a piece of wire to do this. On the short end of that led you solder a piece of blue/yellow/green wire. This must be long enough to be soldered to the positive side of the second led in the array. then solder a black wire to the short end of led #2 and solder the other end to the black wire at number 20.
Red line is red wire, blue line is 'common wire' purple is the led, and green squiggle is the resistor
Double up and you are good to go.
Old Sep 22, 2009 | 07:07 AM
knight_yyz's Avatar
Toolie
To do the signals repeat the procedure but use these pins.
#25 is positive for LH signal, #29 is positive for RH signal. Ground is #30 on M32 plug
But, for the signals, 2 circuits, only one LED on each with a common ground. So recalculate the resistors needed as they are separate power supply. IE, the left and right signals get power from different pins so you need 2 circuits
make sure you don;t get them backwards, or the right will flash when you go left and vice versa.
If you want to get really fancy you can find the led holders and use them as well. But they will block the dispersion of the leds as they will sit too low. Notice the leds i picked have 140* of dispersion to reduce hot spots. Holders are usually only good for about 100*
Old Sep 22, 2009 | 07:11 AM
knight_yyz's Avatar
Toolie
finished product, and yes the dimmer still works...
Old Sep 22, 2009 | 07:14 AM
knight_yyz's Avatar
Toolie
One last thing. In the photo in post 22 you will see the stock bulb holders. You can't use those with the LED's. I used the back of the cluster for demonstration purposes. I used 3M splicing tape to tape the led's in the OEM holes. I also had to bend the legs of the led's to 90*
Here's my first attempt. I have improved upon this but I don't have any pictures. But who cares really? No one but you will know the back looks like ****e.! LOL
Old Sep 22, 2009 | 07:24 AM
jowo9's Avatar
Yeah, with those giant LEDs, it looks pretty good. And that's a good write-up
But I plan on taking the cluster apart, sanding the blue filter, and putting in a whole bunch of smaller LEDs everywhere so I can get a really even, bright white look. I have white displays and blue LEDs everywhere in my car. And I HATE aquamarine ... That color of blue doesn't match. So I want bright white LED faces, evenly lit, with blue needles... As soon as my LEDs get here I'll start!
Old Sep 22, 2009 | 03:52 PM
knight_yyz's Avatar
Toolie
where are you going to buy the blue needles? They are red so white leds will still make them red. scrape off the blue tint and put a blue led and you will get purple.
Old Sep 22, 2009 | 04:47 PM
zidave's Avatar
Nice write up....looks really good
Old Sep 22, 2009 | 04:53 PM
jowo9's Avatar
Sand off the red paint on the back of the needles. Just wait, you'll see
Old Sep 22, 2009 | 05:30 PM
knight_yyz's Avatar
Toolie
do you have the write up on how to remove and install the needles correctly?
Old Sep 22, 2009 | 05:56 PM
danger300z's Avatar
that write up looks intimidating
Old Sep 22, 2009 | 06:10 PM
jowo9's Avatar
-You just need to calibrate them first
(i) Place your key in the ignition and hold in the odometer button.
(ii) Turn the key on while holding the button in.
(iii) Release the button and wait one second.
(iv) Press the button three times. The readout should be all 888's. You can now press, hold, and release the button at your leisure and the needles will go to their default calibration setting. You have to record this so you can put the needles back on on the same place. The system will exit calibration mode when you turn the car off.
-Then you can just pry the needles off
other than this, I plan on figuring the rest out when I do it. I promise I'll do a detailed write-up if everything goes smoothly haha.
Old Oct 8, 2009 | 06:00 PM
avciugroar's Avatar
So I bought a practice cluster to brighten the gauges with the 60+ SMT LED's. I took the cluster apart, and much to my surprise, its different than the one in the pictures in this thread. the picture below shows the back of the board which does not have the magnetic motor things for the needles, its on the front. And the display sheet is one full sheet, instead of seperate panels.
Does anyone know if this will change anything? Maybe you were working on a 5gen, when this is a 5.5 gen... More info needed please!
Old Oct 10, 2009 | 10:26 PM
jowo9's Avatar
-I'm doing the LED conversion this coming week on my 5.5 gen... Metal Maxima did it in this thread on a 5th gen:
http://forums.maxima.org/5th-generat...uster-yet.html
-You see the 'motors' or whatever are on the front. Same as the 5.5 gen. the only difference is the faces (maybe, are they 1 piece on the 5th gen or just the 5.5?) and the fact that the 5.5 gen has 2 digital displays while the 5th just has one... but no, it won't make any difference. Should work just fine I'll find out I guess.
Old Oct 11, 2009 | 01:47 AM
avciugroar's Avatar
Mines a 5.5. and I dont know if it will be the same, look at the clear pieces that distribute the light from the single bulb for each cluster. Is that the same on the 5gens? and from what I can see so far, the 5.5's are one printed sheet for the front, and seperate panels for each gauge on the 5gen.
Let me know how yours goes... I'm going to wait to see how your outcome is lol
Old Oct 11, 2009 | 07:22 AM
knight_yyz's Avatar
Toolie
the premise should be the same, but the clusters are different. The 5th gen uses tons of bulbs, the 5.5 switched to smd's for all the warning lights. My write up was for a 5.5 gen
Old Oct 11, 2009 | 11:55 AM
jowo9's Avatar
huh... that's really weird that knight_yyz's and avciugroar's are both 5.5 gen gauges, yet slightly different... why are the motors/magnets on different sides? (front and back) Maybe it varies from 02-03?? I believe mine is like avciugroar's... and yeah, I'll get back to you about how mine goes. I'll be doing it this week. I'm gonna do a how-to if it all goes well.
Old Oct 11, 2009 | 11:57 AM
knight_yyz's Avatar
Toolie
mines a 6 spd, his is auto, so there are some extra stuff in the auto, tcs, slip pnrd ets...
jowo9's Avatar
oh and avciugroar, did you take a pic of the FRONT of the circuitboard too? if so, could you post it?
Old Oct 11, 2009 | 11:58 AM
jowo9's Avatar
so knight_yyz, you think that whether its a manual or automatic determines whether or not the motors/magnets are on the front or the back of the circuitboard??
Old Oct 11, 2009 | 11:59 AM
avciugroar's Avatar
that is weird.... and certainly, give me just a few minutes, I have to take it apart again
