Do these fans ever shut off?
Old Sep 25, 2009 | 05:47 PM
cmax1's Avatar
I have a 02 se with 109k and both fans keep running and will not shut off. The temp gauge sits slightly below 1/2 all day even in traffic but the fans will not stop running. I dont have the climate control on so is this normal? Could find a answer in the search engine.
Old Sep 25, 2009 | 05:52 PM
Col Ronson's Avatar
why do you want them to turn off? the temp gauge is sitting below the 1/2 mark because the fans are running full blast. if they were off, the temperature would creep upward, no matter how cold it is outside (combustion takes place at a few hundred degrees)
the fans will turn off when you go on the highway or exceed 45 mph or some number like that i believe. thats because the wind from your driving will ventilate better than the fans.
Old Sep 25, 2009 | 05:58 PM
cmax1's Avatar
Just making sure. This is my first foriegn car and my previous (gm) use to turn on and run for a few min and turn off.
Old Sep 25, 2009 | 06:05 PM
Col Ronson's Avatar
don't get me wrong they'll turn off if it gets cool enough. but in case your relays are malfunctioning, early in the morning when your engine is cold, start the car and see if the fans come on with it.
Old Sep 25, 2009 | 06:06 PM
Child_uv_KoRn's Avatar
Bad *** Newb
Unless he has blockage in the radiator (although I guess the temp would go higher)....
The fans should only be noticeable when the coolant is hot enough. If they're running high speed (they're loud when on high so you can't mistake it) when it's cool outside or soon after you start the car, I'd say you might have an issue.
All summer mine only ran full speed during the hottest days (90s). If it's warm, I believe when you turn on the AC it auto. kicks them to high.
As far as running normal speed quite often, I'd say that's business as usual.
Old Sep 25, 2009 | 06:11 PM
and1jr17's Avatar
hmmm. i have a 5.5 and on a hot day, operating temp, with my a/c running i can clearly hear my fan cut on and off.. you might have a problem with your relays or coolant temp sensor... but dont worry as long as it runs all the time as opposed to not running at all.. then its not an issue.
Old Sep 25, 2009 | 06:44 PM
MONTE 01&97 SE's Avatar
Mine did as well and now that its cooler, not running like that. My 370 and wife's G35 did the same thing when it was hot out.
Old Sep 25, 2009 | 06:50 PM
fflint_18's Avatar
Mine never runs above the dot on the temp gauge. About a 1/4 way up. The needle will actually cover the dot.
Since your's is running at 1/2 the fans should be running.
My guess is that you have either a partially blocked radiator, partially closed thermostat, air in the system, or maybe a starting to fail water pump.
Or the anti-freeze could be improperly mixed. If you have too much antifreeze to water ratio it will not cool as efficiently.
Either way I thik it running at 1/2 is too high.
Where in the country do you live??
Old Sep 25, 2009 | 06:56 PM
True, good point. My gauge never gets higher than 1/4 up.
Old Sep 25, 2009 | 09:16 PM
nsnrider's Avatar
i second the notion of having trapped air or low coolant level.
Old Sep 26, 2009 | 06:28 AM
VQP0WER's Avatar
Mine temp gauge is always slightly below the half way mark as well, no matter what temp it is outside, and both fans on all the time. It's been like this for as long as I can remember......
Old Sep 26, 2009 | 07:35 AM
knight_yyz's Avatar
Toolie
thermostat
Old Sep 26, 2009 | 08:02 AM
cmax1's Avatar
Chicago.. I will look again but the coolant was at full level, also the radiator looks new so I may be a issue with the way the coolant was added. Will check and get back.
Old Sep 15, 2016 | 11:55 AM
maxinout93's Avatar
Originally Posted by knight_yyz
thermostat
How do you know its the thermostat?
Old Sep 15, 2016 | 12:08 PM
DennisMik's Avatar
Don't hold your breath waiting for an answer. You bumped a 7 year old thread.
Old Sep 16, 2016 | 02:19 AM
maxinout93's Avatar
Lol and I waiting for the right answer too lol.
Old Dec 18, 2017 | 08:29 PM
Indy Maxima Nut's Avatar
Super old thread, but not sure this was resolved and I am having a similar issue (2000 Max SE auto). After I shut off my car, the fan, oil light headlights (in auto) and a few others all come on for 10-30 seconds like the key is still in the "run" position. One time they ran for nearly an hour (I went inside and when I came out the fans were still on). Car would not start, so disconnected/reconnected battery and things were good again. So now I have to make sure things shut down before I get out of my car, kind of a hastle. Weird it is doing this nearly every time even when the engine is still cold and the fans are not needed or spinning with the engine running. Current codes I am working thru P1320, P0505, P0740 & P0740, none cooling related but all ECM related. No I have not yet checked out my coolant temp sensor yet, but will be the 1st thing I check.
Again, a supper old thread but hoping after all these years a resolution has been found? Thank for any help provided!
Old Dec 18, 2017 | 08:56 PM
DennisMik's Avatar
I don't know what you are trying to say with "all ECM related" but what you did say makes no sense.
The P0740 is an automatic transmission code - The torque converter clutch solenoid valve. You probably will have to replace the solenoid.
P0505 is the Idle Air Control Valve (IACV-AAC). The stepper motor windings have probably shorted out. Usually the car will have a high engine idle when this happens.
P1320 is Ignition Coil Signal. You have one or more bad ignition coils. In cars this old, you may have to replace all the ignition coils due to old age.
Old Dec 19, 2017 | 06:25 PM
The P0740 is an automatic transmission code - The torque converter clutch solenoid valve. You probably will have to replace the solenoid. (After I test it , I will start by trying to grab a couple of these next time I go to the junkyard and try to save money, Nut)
P0505 is the Idle Air Control Valve (IACV-AAC). The stepper motor windings have probably shorted out. Usually the car will have a high engine idle when this happens. (After I test it, I will try disassembly & cleaning, Nut)
(My #5 & #6 test bad, but no mis-fire at all, going to grab some coil packs next time at the junkyard, Nut)
Sorry for the crappy post Dennis, was an end of the night shoot out and I didn't put enough thought into what I was trying to say. But thank you for your reply! I guess what I meant was, none of my current faults are cooling system faults, therefore I'm not sure that any of them have to do with my fan staying on after I turn the car off?? The exception (I believe) could be the P0505, if the bad IACV-AAC has damaged the ECM. Probably my best line of action is to get my current faults repaired & cleared and then see what the fan is doing and troubleshoot from there, unless I receive some suggestions in the mean time. Thanks again Dennis!
Old Dec 20, 2017 | 08:01 PM
DennisMik's Avatar
Miscellaneous comments.
The transmission torque converter clutch solenoid valve is inside the trans, requiring you to remove the valve body. It is also part of of a set of 5 solenoid valves that you have to buy all together as a set.
If the IACV has shorted out, it is very likely that the driver transistor integrated circuit in the ECU burned up. Taking the IACV apart and cleaning it probably will not help. get the FSM and check the stepper motor winding resistance. They should all read about 22 ohms.
See pages 502 and 506 - http://boredmder.com/FSMs/Nissan/Maxima/2000.5/EC.pdf
If the ECU got damaged, the only way to tell is to remove it from the car and open it up and look inside it. See post # 27 for an example of a fried STA509A chip - http://forums.maxima.org/5th-generat...d-seconds.html
The stuff about the lights being on after the ignition is turned off - I don't know. That may take some serious diagnostics.
Miket2006
Mar 1, 2021 03:55 AM
captchaos
Mar 15, 2016 12:18 PM
hayne
Oct 5, 2015 11:53 AM
asianstyle
Sep 10, 2015 11:30 AM
