Auto Headlights.
Old Sep 26, 2009 | 01:23 PM
and1jr17's Avatar
Auto Headlights.
okay.. i have a 5.5 gen.. when the headlight switch is set to to automatic and start the car..they come on just fine.. and for the most part when i turn the car off it stays on for a period of time and then turn off.. just like it should.. within the first week of having the car i went to start it and the battery was dead.. and it did it again last week.. last night i noticed the headlights never turned off...luckily i caught the lights on after 2 hrs or so...and was able to start it.
so whats the problem? any input appreciated.
Old Sep 26, 2009 | 01:54 PM
03VQMAX's Avatar
If you open the passenger side door, turn the ignition on with your auto lights set, then take the key out and leave, they will stay on, happened to me a few months ago and the lights stayed on for about an hour until someone told me they were on. Other than that, shouldn't be any problem.
Old Sep 26, 2009 | 02:02 PM
and1jr17's Avatar
^^^ this isnt the case tho. i park the car at night with the auto lights on.. get out the driver side door.. lock the car and they still stay on..
Old Sep 26, 2009 | 02:32 PM
03VQMAX's Avatar
Hmm that's weird.
Old Sep 26, 2009 | 05:17 PM
maximase86's Avatar
I love lamp.
Sounds like a problem with the battery saver feature. I would start hunting around the control unit.
S
Old Sep 26, 2009 | 05:25 PM
OK.Eric's Avatar
This same thing happened to me a while back. I'm sure it was probably just me accidently flipping the switch to on (maybe when I used the blinker).
So anyway, I just manually turn my lights on and off now.
Old Sep 26, 2009 | 06:08 PM
and1jr17's Avatar
so theres no type of timer that can have gone bad?
Old Sep 26, 2009 | 07:31 PM
6SPD02SE's Avatar
Make sure all of your doors are completely shut. The lights will stay on if the doors are not shut all the way.
Old Sep 26, 2009 | 07:50 PM
Col Ronson's Avatar
at first i had this problem and thought it was the lights but turned out one of my battery cables were loose. check that first, it could be something else draining your battery.
Old Sep 26, 2009 | 08:02 PM
Rochester's Avatar
Me too. Always have.
I think you're better off knowing the lights are off when you turn them off, rather than relying on technology to do it for you long after you've gone inside.
Old Sep 27, 2009 | 02:04 PM
and1jr17's Avatar
^^^ my cables are tight.. im pretty sure its the headlights killing it.. there is no reason if the doors are properly closed and lights set to auto that it should be on 2 hrs after parking the car...
anymore suggestions?
Old Sep 27, 2009 | 11:28 PM
Col Ronson's Avatar
Sounds like the car thinks the key is still plugged in. When i turn off my engine but i sit in my car with the radio on, the lights stay on forever.
AaronL
Aug 8, 2020 10:31 AM
BobTX10
Oct 7, 2015 08:43 AM
Maximeltman
Sep 28, 2015 07:19 PM
dshinn
Sep 26, 2015 08:07 PM
