02 Maxima I think I found the oil leak!
Old Sep 29, 2009 | 01:27 PM
Maury's Avatar
I found an oil puddle under my car ... not on the ground, but the plastic shield under the car's front lip is catching it. I traced it back to the area under the coil packs. Please bear with me I don't know what all these parts are called, but there's fresh oil under coil pack #1 & #2 (LtoR) and also under a brass cylinder type thing. Here are two pics (they're huge, so I'll post a link instead of making this thread giant). Do you guys think this could be why I'm 1-2 qts low between changes?
http://i.b5z.net/i/u/1530927/i/IMG_0544.JPG
http://i.b5z.net/i/u/1530927/i/IMG_0543.JPG
Old Sep 29, 2009 | 01:38 PM
J-Rod's Avatar
Old Sep 29, 2009 | 01:47 PM
Maury's Avatar
Originally Posted by J-Rod
OK I'll bite... what do you suspect the problem is?
Old Sep 29, 2009 | 01:51 PM
Stormzusmc's Avatar
valve cover and seals
http://forums.maxima.org/5th-generat...overs-pic.html
Old Sep 29, 2009 | 01:53 PM
HotshotVQ35's Avatar
do you do your own oil changes? i found some oil on top of my front valve cover, but it was all from accidentally missing the oil fill
Old Sep 29, 2009 | 01:54 PM
Maury's Avatar
Thanks Storm. I'll do a maxima.org search on valve cover & seals. Sounds like I'll have to get my credit card out too.
Old Sep 29, 2009 | 01:55 PM
Maury's Avatar
No, I don't. I'm adding 1-2 qts between the 3000 mile oil change that my garage does. The oil that I found at the bottom of the car is fresh.
Old Sep 29, 2009 | 01:57 PM
Stormzusmc's Avatar
i gave you a link as well
Old Sep 29, 2009 | 02:01 PM
Maury's Avatar
Sorry, I just found that a moment ago - and I posted a reply on that thread. my bad.
Old Sep 29, 2009 | 02:20 PM
J-Rod's Avatar
x2
On top, like that, would be the culprit.
Old Sep 29, 2009 | 02:21 PM
J-Rod's Avatar
Probably still the reason, they (garage) aren't as clean as they need to be.
Old Sep 29, 2009 | 02:22 PM
J-Rod's Avatar
Is this oil leak, constant?
Is it leaving a puddle wherever you park?
Old Sep 29, 2009 | 02:34 PM
Maury's Avatar
The oil leak is constant, yes. I've been adding 1-2 qts between changes for months now.
Old Sep 29, 2009 | 03:02 PM
J-Rod's Avatar
And you really can't tell a area that it is coming from on the motor? Not just the coil packs.
Old Sep 29, 2009 | 03:07 PM
Maury's Avatar
Correct. I know very little about this stuff and I'm just trying to educate myself. I'm sorry if I'm frustrating anyone, but this is so new to me. I loaned my Haynes manual to a friend. Gonna get it back and see what's involved. I wouldn't expect you to believe that what I've showed you proves there's an oil leak there... but its the first time I've ever found any evidence whatsoever of a potential external leak.
Old Sep 29, 2009 | 04:12 PM
Maury's Avatar
I cleaned around the coil packs and I'll keep an eye on this. If there is in fact a leak, I'll see fresh oil there. Maybe my mechanic did simply spill some.
Old Oct 1, 2009 | 09:35 AM
dorman68's Avatar
Spark plug tube seals. My in-laws needed this done not too long ago. Had to buy a valve cover assembly.
MAXSE5SPD
Aug 23, 2015 12:06 PM
minus
Fluids and Lubricants
Aug 18, 2015 07:29 PM
acw
Aug 13, 2015 12:50 AM
Balkins
Aug 12, 2015 06:39 AM
acw
Aug 7, 2015 04:20 PM
