Cruise INOP, reverse lights on, speedo off
Old Oct 5, 2009 | 09:06 PM
avciugroar's Avatar
I feel these issues are connected.
-Cruise control does not work
-Reverse lights stay on ONLY while in gear (6-spd)
-Speedometer is off by 3-7mph
Bought my car two months ago and noticed the reverse lights didnt work. Car lot replaced the bulbs. A friend told me my lights kept flickering after that. Turns out the reverse lights stay on at all times except in neutral.
The speedometer is off about 4mph @ 70mph which makes my MPG's about 32 on the highway, and over a period of 100 ACTUAL miles, my car looses 5 miles.
Long story short, after battling with the dealership, many parts have been changed, and it still does not work.
Items that have been changed:
-Neutral Safety Switch
-Reverse Indicator Switch
-Canister Valve
-Vent Valve
-Cruise Control sensor connected to the brake pedal
-"Manual Transmission Control Assembly" $$$$
Hopefully this thread will be read by a Nissan technician or someone who has had this problem before... any help would be appreciated, I've dumped more money into this issue than needed.
Old Oct 5, 2009 | 09:19 PM
Gemner's Avatar
what size are the tires on the car according to the treadwall? I feel that that is not connected to the rest of the problems
Old Oct 5, 2009 | 09:21 PM
avciugroar's Avatar
Original from what came on the car. 225 50R17.
I also forgot to add that my sister has an 02 GLE, with 225 50R17 tires. I took my GPS in her car and took it down the road and her speedometer is EXACT.
Old Oct 5, 2009 | 09:27 PM
Gemner's Avatar
it sounds like the gear switch on the transmission is malfunctioning/broken. Are you able to get to the ECU and probe connections with a voltmeter?
Old Oct 5, 2009 | 09:29 PM
avciugroar's Avatar
hmm, sure
I have someone who can do that for me, but wouldnt know what to probe.
Old Oct 5, 2009 | 09:33 PM
Gemner's Avatar
you need to look up the wiring diagrams in the FSM. I had a problem where my cruise control would not work, and found that this can be caused by a few things: brake pedal sensor problem, gear select sensor problem, clutch sensor problem and maybe something else. For me, my gear select switch on the transmission was broken (literally) and I ended up wiring in a switch to the clutch pedal to fix it. If you go through the troubleshooting in the FSM and follow every step you should be able to fix this. I would start by working back from the cruise control problem
Old Oct 5, 2009 | 09:41 PM
avciugroar's Avatar
Please tell me you know where the FSM is... I just did a search and only came across something else to spend money on; a switchblade flip key remote lol.
Old Oct 5, 2009 | 10:51 PM
SuperStasiu's Avatar
http://boredmder.com/FSM/Nissan/Maxi...MPLETE-FSM.zip
Old Oct 5, 2009 | 11:56 PM
kbohip's Avatar
-Canister Valve
-Vent Valve
Louisiana? Hopefully this is not a flood damaged car. I say that because these seem like unusual problems to be having. Was there a Carfax run on this when you bought it?
Old Oct 6, 2009 | 10:14 AM
avciugroar's Avatar
Thank you much for the FSM!
and yeah I demanded a carfax just like on the commercials lol. The sales manager procrastinated with it, and didnt get it to me until after I signed the papers, but I still got it.
I'm the 4th owner, and it was kept in Baton Rouge with one owner, a suburb with another owner, and in Lafayette which is where I live...
While its not a New Orleans vehicle, you still never know! But I've taken a few things apart on it, and I didnt see any signs like I had on my last vehicle, a Sentra, who was unfortunately a Katrina victim (which is why I got such a good deal on it!)
Old Oct 7, 2009 | 03:13 AM
avciugroar's Avatar
bump
Old Oct 8, 2009 | 02:51 AM
avciugroar's Avatar
bump it up
Old Oct 8, 2009 | 11:32 PM
avciugroar's Avatar
Old Oct 8, 2009 | 11:59 PM
Gemner's Avatar
what did you find from probing the ECU?
MR2 T'd
Jul 9, 2021 05:06 AM
mvm062
Nov 30, 2020 09:00 AM
fastcarny
Oct 6, 2015 10:42 AM
minsbang
Sep 11, 2015 08:48 PM
Maxima30
Sep 7, 2015 06:13 PM
