clutch set ups?
Old Oct 11, 2009 | 10:41 AM
dat01max's Avatar
clutch set ups?
im going to need a clutch soon... i wanted to know what kind of set ups are good and which one i should get... i remember seeing a thread all about the different clutches but i cant find it...help?...its goin on a 3.5
Old Oct 11, 2009 | 07:34 PM
Unklejoe's Avatar
350z clutch-fidanza flywheel
-sprung disc
-unsprung flywheel
exedy oem replacement (#NSK1002)-replacement OEM flywheel
-unsprung disc
-dual mass (sprung) flywheel
It is possible to replace the clutch with the OEM Exedy replacement without getting a new flywheel, but the stock dual mass flywheel cannot be re machined, so the best you can do is clean it.
It it recommended to just get a new dual mass oem flywheel if your going to go with the OEM replacement route because dual mass flywheels are considered a "maintenance" item and should be replaced.
Also, make sure that with what ever setup you go with, you have only one sprung element. For example, the 350z clutch disc is sprung, so the flywheel is not. The oem exedy replacement is an unsprung disc, so the flywheel must be of the dual mass type.
I'd go with the OEM 350z clutch replacement and Fidanza flywheel if I were you. Supposedly a better clutch feel and stronger clamping force.
Old Oct 11, 2009 | 07:59 PM
dat01max's Avatar
so i cant use the exedy stage 1 clutch with the fidanza flywheel?? and i read also that the exedy clutch is just a tad bit beefier than the 350z clutch
Old Oct 12, 2009 | 05:36 AM
Unklejoe's Avatar
You can use the Exedy stage 1 clutch with the Fidanza, but the 350z clutch is almost the same and for a much lower price. You can't use the Exedy stage 1 clutch with the stock flywheel however. (unless you want a really jolty ride)
Old Oct 12, 2009 | 06:10 AM
dat01max's Avatar
Is it ok to buy a used setup with very low miles... I would guess that the 350z clutch is better then our stock clutch
Old Oct 12, 2009 | 06:29 AM
TallTom's Avatar
Would you buy used brake pads?
Old Oct 12, 2009 | 06:36 AM
dat01max's Avatar
That was a good one lol your right
derekinthez
Nov 13, 2022 04:00 PM
Mar 12, 2020 12:06 AM
BkGreen97
Apr 2, 2016 05:47 AM
ef9
Sep 10, 2015 10:35 PM
