Afternarketr lights melted my harness!!!!!
Old Dec 1, 2001 | 08:50 AM
rocketshipon19"'s Avatar
Has anyones elses aftermarket lights melt their harness? If so how much does it cost to repair?
Old Dec 1, 2001 | 09:04 AM
FloMax's Avatar
Re: Afternarketr lights melted my harness!!!!!
I have heard about that happening to 3rd gens frequently. I guess you will either have to buy new harnesses, get some off a wrecked 5th gen, or buy the 2k2 HIDs.
Old Dec 1, 2001 | 12:18 PM
Re: Afternarket lights melted my harness!!!!!
Has anyone elses aftermarket lights melted their harness? If so how much does it cost to repair?
Old Dec 1, 2001 | 03:28 PM
nisMAXse's Avatar
Re:
Were you running 85-watt bulbs...?? How long were you running aftermarket bulbs?
Old Dec 1, 2001 | 03:53 PM
Re: Re:
Yup, 85watt PIAA's to be exact. They have been in car for a little over 18mos.
Old Dec 1, 2001 | 04:18 PM
cwally's Avatar
Mine melted about 6 months ago, and a dealership told me that to fix it, they had to replace the whole harness which costs $650 + labor, becuase they do not sell just the plug, they sell the whole harness from the light all the way back. Took it to another dealer talked to one of the mechanics, and hetold me that he could put a plug from a new nissan truck. <-Because for the truck I could buy just the plug. Ended up doing that, and it cost me 75 bucks...
Old Dec 1, 2001 | 05:39 PM
Re: Re: Afternarketr lights melted my harness!!!!!
Good looking out! I'll try that. when your harness melted, did it cause your low beam not to work?
Old Dec 1, 2001 | 07:45 PM
cwally's Avatar
Re: Re: Re: Afternarketr lights melted my harness!!!!!
Yeah... At first I thought that the plug had come lose, because when I moved the plug, it would come back on. It was melted inside, but I had never noticed, I would just push it in harder to make it work. So when I finally decided to take it out to look what the problem was, it came off hal melted. And yeah, it caused my low beam not to work.
Old Dec 1, 2001 | 11:13 PM
ItalianMax2kSE's Avatar
I was running some HyperWhite H4's I got from eBay. Not cheap ones, they were nice. 55watts, just like stock. (only bulbs on my car that are not PIAA cause they were nice) a ciuple days ago, my driver side headlight harness melted! I called DaveB and orderd a new wire harness for $8 shipped! He said the bulb probally just blew. Time for PIAAs I guess.
Old Dec 2, 2001 | 12:00 AM
bigbadboss101's Avatar
I had some aftermarket lights in my 99 and after just over a year one of the plug melted. The low beam would not work, but the high did.
I took in to the dealer to get it fixed. If you can do it yourself, order the part and do it. The dealer charged me $160 or so, most of which was labour.
Old Dec 2, 2001 | 12:15 AM
2001SE's Avatar
You should run 55w...so what do you expect when you put the 85w...that you would just get more light made with the same wattage as the stock one
Did you know it would have melted before you put the Piaa?
Old Dec 2, 2001 | 12:17 AM
Tony Fernandes's Avatar
Man, I hope I have nothing to worry about. I got the PIAA Xtreme whites 55W=85W. I did this specifically because I was under the impression that they only draw 55W, yet put out light equivalent to an 85W bulb.
Tony
Old Dec 2, 2001 | 12:47 AM
2001SE's Avatar
Tony
There are 2 H4 PIAA options, 55w and 85w. The maxima runs on 55w and if you put the 85w it will just melt your harness like rockethship...it takes time but doesn't worth it. if i remember correctly the 55w puts out a light eqivalent to 110w but i personally think its all BS...get he real 2k2 HID's and then see what's real lights
Old Dec 2, 2001 | 06:28 AM
Dario's Avatar
Before you go spending more than 10.00 dollars try going to a pep boys and look for the harness. i spent about $7 bucks and just replaced the crispy one. its not that hard just cut off the old one and then wire it to the new one, their should be three wires.
Old Dec 2, 2001 | 10:48 AM
Re: Re: Re: Re: Afternarketr lights melted my harness!!!!!
Man that sounds like what I was doing! Sometimes I would be able to flicker the high beams and they would come on! Most times I would jiggle the harness and it would come on!
The Frye
Sep 2, 2021 11:03 AM
mvm062
Nov 30, 2020 09:00 AM
minsbang
Sep 11, 2015 08:48 PM
Maxima30
Sep 7, 2015 06:13 PM
JoshG
Sep 5, 2015 10:10 PM
