i hear/feel my clutch pedal squeaking...?
Old Oct 17, 2009 | 06:29 PM
NissanMan97's Avatar
i hear/feel my clutch pedal squeaking...its annoying but is it bad?
like the title says i hear/feel my clutch pedal squeaking or rubbing or grinding i dont know what it is. the best way to describe the sounds is if you take two pieces of hard plastic/rubber with rough surfaces and rub them together (i know but that is the best i can come up with). Its not impeding my shifting ability or anything and the clutch goes in smooth (as far as I can tell) its just the weird noise thing .
I might be over paranoid because i just lost my car that was mechanically sound. is this something i can throw a little WD-40 on and call it a day or is there a better solution.
Thanks in advanced.
B
Old Oct 17, 2009 | 06:46 PM
bigpopaj369's Avatar
it kinda sounds like its just a wear n tear squeek, my friends 00 5spd does the same thing before and after he got a new clutch installed.
Old Oct 17, 2009 | 06:49 PM
are you saying my clutch may be going out?
B
Old Oct 17, 2009 | 06:51 PM
no i think its just a squeek from the pedal. my dads old camaro did the same thing same with most of the other over 5 year old standard cars ive driven
Old Oct 17, 2009 | 06:55 PM
oh ok....its the a fix? or am i stuck with it?
B
Old Oct 17, 2009 | 06:58 PM
ive heard of people lubin it up so i wouldnt see why not. i cant say for a definite yes thats what it is but if the clutch seems good then its prolly a good bet thats all it is
Old Oct 17, 2009 | 07:07 PM
cool thanks!
B
Old Oct 17, 2009 | 07:09 PM
no prob man GL hope thats all it is
Old Oct 17, 2009 | 07:15 PM
lol...me too
B
Old Oct 18, 2009 | 07:03 PM
maxboy01AE's Avatar
mine was fine all summer it just start doing i like a week ago. weather might be the issue..
Old Oct 19, 2009 | 06:07 AM
good point...i got the car when it was a little warmer and just noticed it since its gotten colder
B
Old Oct 19, 2009 | 03:01 PM
LoveSick's Avatar
B
Many of my older cars had that. It could be the pin on the hinge or the pedal spring causing causing this sound. To solve it, simply spray lube such as WD40 directly onto the pedal spring or the pivot pin. It should go away, depending on where the squeak is coming from.
Old Oct 19, 2009 | 03:45 PM
vinco's Avatar
If the flex line or the slave cylinder is going bad, it can/will make a wierd squeaking noise. Mine did it not too long before the slave went out. I replaced the slave cylinder and replaced the flex line with a stainless-steel braided line. Fixed the squeak.
Old Oct 20, 2009 | 04:57 AM
thanks ill keep that in mind
B
Old Oct 20, 2009 | 12:40 PM
zero2sixtyZ's Avatar
You embarrass me.
I've had to spray some lithium grease on my clutch pedal spring many a time. Works great, just when the squeak comes back, crawl under, cover your face and spray onto the spring.
ef9
Oct 4, 2015 08:43 AM
leatherneck
Sep 30, 2015 09:16 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
salty318
Sep 29, 2015 01:21 PM
salty318
Sep 28, 2015 07:22 PM
