Testing A33 IACV, need member input
Old Oct 19, 2009 | 08:23 PM
shadyonedeath's Avatar
I need a favor from you guys with working 5th gen Idle Air Control Valves. The FSM has a testing procedure that requires you to remove the IACV from the Throttle body but leaving the connector plugged in.
It claims if you turn the key to IGN (not turn the car ON, but to light up all the gauge cluster lights), that the IACV should move up and down as you turn the key on/off.
Can you guys check to see how much the valve moves up and down when your turn the key to ON position and off? I tried it on mine and im trying to rule out if my ECU is fried from trying to use a A33 IACV on a 4th gen 00vi. Both my A32 and A33 IACV's move but it only a tiny bit. Not noticeably enough to control air flow. Like 1-2mm.
Thanks.
Old May 29, 2011 | 05:59 AM
maxspeed96CT's Avatar
The original VQ...
any updates on how you made out?
I have a 01 and id like to test mine without removing it.
Old May 29, 2011 | 07:56 PM
IVIaxima's Avatar
In order to test the IACV you need a volt meter, T-pins go to the conecctor of the IACV and test the connections... I used to have an actual picture of what connector is wich but idr where i put it ill try to find it for you...Basically they have to be with in a certain voltage... if there out of spec then you know to replace it thats one way to test it another is to use a scanner wich not alot of people have access to.. thats all ik so far
tarun900
19
Dec 20, 2021 06:57 PM
Apr 16, 2020 05:15 AM
gigabyte
Jan 6, 2017 06:05 PM
knight_yyz
Nov 1, 2015 01:34 PM
Tmax78
Sep 25, 2015 09:07 PM
