Question regarding Tein SS coilovers.
Old Oct 20, 2009 | 10:06 AM
viperxbr's Avatar
A quick question about height adjustment on the Tein SS. From what I can tell, when you increase the height of these coilovers, you're effectively increasing the preload of the spring by raising the spring perch.
Is this true?
Or is there clearance for the rod in the strut/shock to extend up with the spring?
I want to adjust the height to around -1.6 - -1.8 in the front and -1.0 - -1.3 in the rear, preferably without changing the preload.
Thanks.
Old Oct 20, 2009 | 10:18 AM
rroderiques77's Avatar
Demodded and Forgotten
KSports have the ability to do so. I am sure yours do as well.
Old Oct 20, 2009 | 10:20 AM
viperxbr's Avatar
Thanks for the response but I haven't bought them yet. Still doing some research before I decide.
Old Oct 22, 2009 | 06:57 AM
viperxbr's Avatar
Bump.
Old Oct 22, 2009 | 07:31 AM
Phantom-V's Avatar
Is this true?
Thanks.
i think this is what your looking for...not to sure. once you do the adjustements, your basically turning the heightner rings to the ride height you desire. the springs remain on the perch but are tightened or loosened when you do the adjustments unless your doing it while the coilover are still on the car while your adjusting.
Don't know if that helps you at all.
Unclejunebug
Apr 2, 2016 05:42 AM
Stagnet04
Oct 11, 2015 08:16 PM
Socalstillen
Sep 26, 2015 12:01 PM
