Oil filters that stops the clatter on start up.
I did a search and couldnt find my answer but I have a 02 max and I get the clatter on start up. I see that filters with anti drain back valves stop that but no names of filters were mentioned. Im using regular motor oil but I seen a lot of synthetic users have mobile 1 filters. the car has 110k on it.
I could have sworn I read that the oil draining back past the filter is what causes the clatter and the guide not having pressure on it. Not in that exact wording of course.
I personally use OEM filter
and the clutter is this
http://maxima.theowensfamily.com/tsb/NTB03-060.pdf
Just for laughs, I'll try using a mobil-1 filter next time. I have the VCT noise, but I know ifI take it to the dealer it'll be discarded b/c I still have a warranty, or it won't happen at that point. Normal dealer BS. I've used Ford motorcraft filters and now an OEM Nissan filter, noise is still there.
The clatter is normal. IF it is persistent on every start-up even on a warm engine, then you may have a clogged oil circulation system. Running seafoam or oil crankcase cleaner will clean it up.
If'n you have it - you have it (the rattle).
Had mine since day 1 off the lot - it only gets worse occaisionally, and usually in cold weather.
no worthwhile, or cost effective cure - just one of those added "bonuses" the Nissan
engineers built-into the 5.5!
I ran M1 filters for a while, and just switched to a comparable WIX -- almost half price, and >/= to the quality of M1, as long as you're not looking to extend your OCI's past 7500k, which I don't.
Those dam M1's are up to almost $13-14 a pop now.
Wix Part # 51356
http://www.wixfilters.com/filterlook...&TempYear=2002
Shoot Talkinghorse a PM - he'll hook you up!
gr
trasmadean
Jan 20, 2018 05:05 AM
kirkhilles
Aug 8, 2015 10:53 AM
