Downhill Lag?
Old Nov 16, 2009 | 05:21 PM
ZGadson's Avatar
Downhill Lag?
I've been noticing that since I moved to Georgia (where its very hilly), my car rides downhill funny - almost as if I'm riding the brakes, or coasting in 1st gear, because if I put it in neutral when coasting downhill, it feels like it rolls easier. In drive, if I keep my foot barely on the gas, it also seems to even out the lag.
Is this normal?
Old Nov 16, 2009 | 05:48 PM
Rood's Avatar
same in my old toyota camry, auto.
Old Nov 16, 2009 | 06:04 PM
AEMAXIMA01's Avatar
Normal for an Auto.
Old Nov 16, 2009 | 08:03 PM
Christobal65's Avatar
Down Hill completely off the throttle and it seems to drag? That's normal. The ECU in most cars are programed to cut all fuel to the engine and just use the drive train to keep the engine spinning. Maximas seem to cut off the fuel and add it back rather abruptly.
Old Nov 16, 2009 | 08:07 PM
Gemner's Avatar
+1 above, the injectors pulse something like 2ms when at very low to no throttle. This will obviously make it feel like youre draggin the brakes. If you want to really have fun, reroute the breather from the front cover and just put a filter on it, then plug the outlet from the intake tubing. You get this awesome pulsing of power at low throttle %'s. bucking bronco FTW?
Old Nov 16, 2009 | 08:10 PM
wait you can make the car buck in 1st gear (MT) worse than it already does stock?
Old Nov 16, 2009 | 08:21 PM
jasonmax's Avatar
its called engine brake
many new auto trannies even downshift when going downhill.
Old Nov 16, 2009 | 09:40 PM
Gemner's Avatar
well, im not sure that its worse, but its different and bad. I logged the a/f when my car was doing that and it turned out that the engine was cycling on and off the fuel, so it was cutting fuel like in engine brake mode, then it would give it fuel again, then back into brake mode, it would do it pretty quick so the car definitely bucked.
Old Nov 16, 2009 | 10:47 PM
ZGadson's Avatar
My car doesnt buck, persay, but it definately seems like it has a big kick when you give it gas during or after coasting downhill.
I had my car at the dealer for some work a few months ago and they loaned me a G37 coupe (didn't want to give it back) but it did the same thing only worse. I called the dealer to ask about it (thinking I F*ed up their loaner or something), but they gave me some bull**** answer about traction control and something else. Didn't know if it was related or not.
Old Nov 16, 2009 | 10:54 PM
Manual cars can really kinda buck when you release and get on the gas in 1st gear, autos aren't as susceptible.
Old Nov 17, 2009 | 04:06 AM
AEMAXIMA01's Avatar
Just a technique that takes a little mastering. My 5th gen is a lot easier to keep from bucking than my 4th gen was.
Old Nov 17, 2009 | 06:43 AM
01Anniv20147's Avatar
Finally someone experiences the same problem. Funny thing i got the same line of s@#$ from the dealer you did...NO PROBLEM FOUND. Its VERY annoying but I havent experienced it in my 5th gen only my 06 Altima. PITA!
Old Nov 17, 2009 | 09:56 AM
jasonmax's Avatar
its because auto doesnt lock up the torque converter till its in overdrive.
if you autobox can lock its torque converter in 1st, it would buck too.
Old Nov 17, 2009 | 10:48 AM
i agree, my mom has a 4th gen and it is a pita to drive smoothly in 1st gear in a parking lot or traffic
that's basically what i said just with out the techno-babble. Also the torque converter does lock up in the lower gears its just not always locked like it is in OD. In the lower gears it locks up at a specific rpm.
Old Nov 17, 2009 | 12:00 PM
FlipCpt45's Avatar
OT, but trying going downhill and hitting the fuel cut is like hitting a brick wall.. (135mph limiter on autos)
Old Nov 17, 2009 | 12:40 PM
Gemner's Avatar
The 135 mph limiter is a soft limiter though, it would be worse at a rev limit fuel cut
Old Nov 17, 2009 | 01:02 PM
FlipCpt45's Avatar
thats soft huh.i thought my car was going to blow up when i hit it :P lol
then again it was awhile back.. i normally don't go that fast anyways... maybe if i was supercharged on the other hand.. lol
MidnightMaxima_22
Sep 6, 2015 01:18 PM
FanaticMadMax
Aug 10, 2015 08:55 PM
Pmp-n8a
Dec 18, 2001 06:41 PM
Cumalot
Oct 21, 2001 09:05 AM
Keven97SE
Aug 25, 2000 05:41 AM
