Speedometer Sticks Sometimes
Old Nov 24, 2009 | 10:31 AM
jarturo's Avatar
I have a 2000 SE 5 speed that the speedometer gets stuck only when crusing at a constant speed between 70-75mph. If the speed varies then it does not stick.
If the car is turned off then the speedometer resets and works correctly.
Any ideas as to what is the problem- the speedometer or the vehicle speed sensor?
Old Jan 17, 2010 | 08:33 PM
jarturo's Avatar
Bump for Help.............
Old Jan 17, 2010 | 08:51 PM
beefy23b/97's Avatar
If your speed is constant then your speedometer shouldn't move. When I'm going 65 my speedo doesn't move either, until I take my foot off the gas thus varying my speed and my speedo then moves down.
Old Jan 17, 2010 | 09:07 PM
jarturo's Avatar
Yes, and when I take my foot off the gas the car slows down and the speedometer needle stays where it was (ie, 70MPH when I'm going allot slower). If I turn the car off then the needle drops back to zero and works OK until I drive at a steady speed for several minutes and it sticks at that speed even if I slow down or speed up.
Old Jan 17, 2010 | 10:58 PM
OIC sounds like a sensor. But I've never had that happen so I'm purely guessing.
Old Jan 18, 2010 | 11:12 AM
914Max914's Avatar
thats so wierd my car does the same >=|
Old Jan 18, 2010 | 02:21 PM
Maxima112's Avatar
Curb Rash Repair 100 a wheel
do you guys have the paradox chrome gauge rings installed? sound simple, but if it just got hot the glue tends to melt a little and the whole ring falls down juuuust enough to catch your needle (where 70MPH is, the top), hard to see but its possible (happened to me) and when you turn off the car the engine shaking could vibrate it loose.
MR2 T'd
Jul 9, 2021 05:06 AM
HerpDerp1919
Sep 29, 2015 02:02 PM
jchronis2552
Sep 21, 2015 05:52 AM
Djsmaxima
Sep 14, 2015 11:58 PM
