help Adjusting the Camber on 95 maxima.
Old Nov 28, 2009 | 04:22 PM
TravisCadello's Avatar
I've got two questions. one is i changed my tie rod ends inner and outter and did the alignment by eye. my question about this is should the wheel be dead in center and both front tires perfectly straight? or should both tires be slightly pointing outward or in ward? someone told me their not supposed to be adjust straight for some reason is this true? Thanks,
And another is where do i adjust the camber? mine is having a lot of positive camber and werarin the outside of the tire out fast i just wanna make it a bit straighter but dont know how to adjust it.
Thanks guys!
Old Nov 28, 2009 | 05:00 PM
whiteSE's Avatar
wrong section
Old Nov 28, 2009 | 05:31 PM
Can Someone replace this into correct section then?
Old Dec 19, 2009 | 01:16 AM
Could i do it by myself to set it alittle more centered?
Mine is off badly.
Old Dec 19, 2009 | 01:38 AM
Mr. Brett's Avatar
Check Advanced Suspension or Fourth Gen forums. They can probably help you a bit more than we can...
tarun900
19
Dec 20, 2021 06:57 PM
bigfrank
Oct 1, 2015 12:51 PM
leatherneck
Sep 30, 2015 09:16 PM
