Driver side FOG and CORNER light. Not working.
Old Dec 17, 2009 | 01:53 PM
TMAXDOUT's Avatar
OK, So i bought the car and the driver side fog light and corner marker did not work. I just figured they were both just blown since the pass. side worked fine. I never really got around to replacing them because i was just going to wait until i got HIDs for the fogs.
problem! Today i got the HIDs went to install them but the Driver side fog still doesnt work after i installed them!!!!
Already checked fuses that say Fog inside and by the battery under the hood.
Any other suggestions???
When installing the HID all i did was unplug the Positive and Negative (female) coming from the wheel well and connect to the (male) positive and negative coming from the Hid kit. Right???
Old Dec 17, 2009 | 02:00 PM
nalc's Avatar
Did you check the relays in the fuse box? Take a multimeter and see if you're getting any voltage at the bulb sockets?
Old Dec 17, 2009 | 02:02 PM
TMAXDOUT's Avatar
using a voltage meter is my next step. But if im not getting any power. Than what could be the problem? Also if the relay is bad, will that cause only 1 fog light to go out?
Old Dec 17, 2009 | 05:06 PM
nalc's Avatar
IDK... I know on the 4th gen, the passengers and drivers side headlights and foglights have separate fuses. So the 5th gen might have a different relay for each side.
The Frye
Sep 2, 2021 11:03 AM
AcuraLegend
Oct 17, 2016 08:47 PM
AcuraLegend
Sep 22, 2015 04:22 PM
maximusrising
Sep 2, 2015 09:55 AM
A32goldylocks
Sep 2, 2015 06:39 AM
