will a 6th gen maf sensor fit a 5.5??
Old Dec 23, 2009 | 01:02 PM
BLACKKILA.GTR's Avatar
ight i think my maf is pretty much on its way out and if im gonna get a replacement i want to get a performance one.. i was looking at the 6th gen maf sensor and found this from the 6th gen section
http://www.ajusa.com/details/index/141/0/8949/JET+69138
so pretty much i wanna know if i can just plug and play this to my 5.5 gen or do i have to get a 6th gen maf tube also// please any info will help..
Old Dec 23, 2009 | 03:09 PM
mist max2000's Avatar
not plug and play...,..the sensor plug is different and the maf mounting point in terms of how the sensor sits is differennt,..
not sure if you can splice it in with the 6G maf tube,.. but i know we have the IAT in the sensor where i dont think they do.. not sure though...so if thats the case you shouldn't even be able to wire it in...
what i can say is that you can salvage your IAT off your 5.5 sensor.. and buy a stronger 2001 sensor (~100 shipped) and DIY the IAT into the new sensor...there was a recent thread about it with great pictures.. prob only a page or 2 deep..
and FYI- replacement OEM 5.5gen is ~400 bucks..
Old Dec 23, 2009 | 09:59 PM
CMax03's Avatar
00-01 has an IAT sensor,...02-03 doesn't...at least the IAT is separate and mounted inside the air intake duct work
Old Dec 24, 2009 | 12:50 AM
knight_yyz's Avatar
Toolie
that's kind of vague... the 00-01 IAT sensor is in the ductwork, the 02-03 is in the maf sensor
Old Dec 24, 2009 | 05:19 AM
Rochester's Avatar
It feels like this thread is muddying things up, which is annoying because all the MAF threads and comments over the last few months had done an excellent job of bringing clarity to this issue. Particularly ridinwitha35's and MIK3's recent threads, and 2slow's experimentation with a separately purchased thermistor for the IAT. There was fantastic info there.I wasn't aware there was an aftermarket MAF for the 6th Gen. Which begs the question: why isn't there an aftermarket 5.0 and 5.5 gen MAF?
And what the heck is a "performance MAF" anyway?
Old Dec 24, 2009 | 05:31 AM
yeah.. if you look in the 6g forms ther is a review about it with a few members with testimonials..they all say they felt something for the most part..i think chernmax started the thread..i think jet makes one for the nissan titan too and you can google search their forms
Old Dec 24, 2009 | 05:42 AM
Rochester's Avatar
Hmm... here's that thread, reading it now: http://forums.maxima.org/6th-generat...af-sensor.html
[edited] not a lot of info there
Old Dec 24, 2009 | 07:31 AM
2slow's Avatar
There is no such thing as a performance MAF or any other instrument. Unless the performance version provides greater resolution or update rates, which doesn't apply to a MAF.
The JET MAF may have a slightly different relationship between airflow and voltage. It may give a slightly different voltage curve (than stock) at WOT which causes the ECU to run more ignition timing. The same (or better) result can be had through proper dyno tuning; tuning would then also remove all value from the modified air flow to voltage relationship.
Just purchase a 2K1 MAF; search for part number 22680-2Y001 at everythingnissan.com as it can be had for $77.69 without shipping/taxes.
Old Dec 24, 2009 | 07:34 AM
knight_yyz's Avatar
Toolie
ya, not much info, lot's of butt dynos but no definitive proof. But I guess it doesn't matter since they don't make one for us. I'm pretty sure that the bolt pattern on the 6th gen MAF is different than ours, and the sensor shape and bolt pattern there is different as well, so even if it coould be wired up to our setup, you would need to have a different setup on the car. IE no stock airbox, you would need a WAI with a new maf adapter
Old Dec 24, 2009 | 08:01 AM
Rochester's Avatar
I'm assuming that's the one you're using for your experiment, right, 2slow?
BTW, shipping charges apply; but still, great price.
Old Dec 24, 2009 | 08:06 AM
2slow's Avatar
That's the one I'm using, albeit I purchased mine from DaveB ($83.36). I should have said not including shipping/taxes rather than without; shipping should be less than $10.
Finkle
Sep 27, 2015 09:53 PM
tcb_02_max
Sep 23, 2015 06:18 AM
vanebecker
Aug 19, 2015 09:45 AM
