P0113, 2k1 to 2k2 MAF swap, ANNOYING!
Old Dec 30, 2009 | 01:05 PM
MIK3's Avatar
So when I did the 2k1 to 2k2 MAF swap, swapped the IAT sensor and now CEL. It's been on actually since the MAF blew three weeks ago. I need to pass emissions and this is my only code I'm throwing.
Thinking of taking the MAF apart, re-installing the IAT again and undoing the battery terminal...letting it sit and seeing if that does anything. I cleared it two days ago and it came back. Anyone else who has done this swap having this issue? I want to stand by this swap, but if I can't pass emissions, I might have to reconsider
Old Dec 30, 2009 | 01:16 PM
Rochester's Avatar
Isn't P0113 the code for your IAT, and not the MAF? Have you taken the MAF out and eyeballed the IAT sensor... maybe it came lose when you swapped it?
If the sensor itself is damaged, you can buy a replacement sensor all by itself. 2slow is running that experiment right now, in the same thread where you got inspired to do this swap in the first place. Last I read, he was still running without a SES.
Old Dec 30, 2009 | 01:17 PM
SuperStasiu's Avatar
try redoing it make sure you clamp the sensor in there pretty tight also maybe try cleaning that sensor maybe with a qtip with some alcohol on it
Old Dec 30, 2009 | 03:10 PM
MIK3's Avatar
Well I took apart the MAF and cleaned the IAT. Gonna throw it back on and see if it works. If not, I'll order a new one. Hmm.
Old Dec 30, 2009 | 09:03 PM
MIK3's Avatar
Yeah, no luck. Gonna see if I can find just the IAT sensor. Maybe it's faulty after the swap. I don't believe I did anything to it.
Old Dec 31, 2009 | 06:29 AM
Shift_Max's Avatar
i doubt you will be able to just find the IAT sensor.
Old Dec 31, 2009 | 06:55 AM
2slow's Avatar
Try soldering the thermistor in place rather than just crimping.
I currently do not have a CEL with the replacement thermistor.
Old Dec 31, 2009 | 07:24 AM
Rochester's Avatar
http://forums.maxima.org/7318741-post34.html
That makes sense. Did you solder the connections, 2slow?
Old Dec 31, 2009 | 07:32 AM
2slow's Avatar
Oh, that makes a lot of sense. Did you solder the connections?
I soldered the thermistor joints so they could be removed if it was incorrect.
Old Dec 31, 2009 | 12:24 PM
ridinwitha35's Avatar
OK, so P0113 means circuit had a high input. Now assuming the MAF you bought is good, I would say that either: a) sensor is bad or b) harness/connectors are bad.
Based on the process starting at EC-196 in the FSM, you should verify 5 Volts at pin 5 of the MAF connector (car on). You should then verify continuity between pin 3 and ground (car off).
Those pins (5 & 3) should directly correspond to the two terminals sticking out of the MAF that hold the thermistor, so you should run the same tests on those.
However, first thing I would check is the resistance of the thermistor...at room temp (77F), it should be around 2K Ohm.
And since P0113 means high input, I would guess the thermistor may be internally shorted (corresponding to a resistance much lower than 2K Ohm), a short in the MAF connector between pins 3 and 5, or a short in the harness between those pins either along the length of the wire or at the ECM.
Old Dec 31, 2009 | 12:46 PM
MIK3's Avatar
Originally Posted by ridinwitha35
OK, so P0113 means circuit had a high input. Now assuming the MAF you bought is good, I would...... of the wire or at the ECM.
Wow, excellent information. I will attempt to measure resistance today and check pins 3 and 5. Thank you guys for all the contributions. I shall keep you all updated.
Also, 2slow: With your situation, were you throwing a CED prior to the Honeywell thermistor transplant, soldered this in, and then the CEL disappeared?
Old Dec 31, 2009 | 02:13 PM
2slow's Avatar
My Maxima never generated a CEL with this transplant. Although, I never tried the 2k1 MAF without the Honeywell thermistor.
Good luck.
Old Jan 3, 2010 | 12:49 PM
MIK3's Avatar
Well on my way home from work yesterday, it turned off. Which is a relief. I was only throwing that code. Apparently I am good to go now! All I did was clean the thermistor and re-clamp. I don't know why that helped. I now have an order of 5 thermistors on the way that I will not need. Oh well! If anyone needs one, let me know.
TallTom
57
Oct 14, 2025 05:16 PM
jmlee44
Oct 2, 2022 02:13 PM
tarun900
19
Dec 20, 2021 06:57 PM
gavin68
Sep 18, 2021 12:36 PM
mpbclutch33
Dec 26, 2015 11:11 AM
