Cold Engine/Cold Weather Start Up Issue
Old Jan 4, 2010 | 10:34 AM
UGAd13's Avatar
For the past couple of weeks my car has been having some cold engine/cold weather start up issues. SES light came on and got the code pulled - Misfire in cylinder #6. Could be bad coil or spark plug, so I changed out all the plugs (needed them changed anyway). Code went away and the car seemed to run fine for a week or two. This morning the issue came back...
Inital start up on cold engine (in cold weather - 40/50 degrees in garage 20 degrees outside) the car has a rough idle under load, in D or R, but not in N or P. The SES lighted flashed for a few seconds but didn't stay on and after about a 5 min warmup the car runs normal.
Car Stats:
'03
112k miles
Change fluids regularly (can't remember if I put in 5w30 or 10w30)
New OEM plugs
No other major maintenance issues
Can it be anything other than a bad coil and if so, do I have to change all 6 or can I just change out the 1?
Anything else I can check or is my car just like me and it hates cold weather? (live in GA)
Old Jan 4, 2010 | 11:24 AM
jasonmax's Avatar
could be a bad coil
you can just change one
check connection
tbh, 20 is meh, try -15
Old Jan 4, 2010 | 08:09 PM
MAXXED_816's Avatar
With the weather i've had the max parked and driving my f-150. I got in the max this morning to check up on it and the e-brake light and battery light came on. I let her get warm and moved her around on the driveway. I took her out later on to go to the bank and no lights were on. Kinda in the same boat, doesnt seem like anything to worry about, just cooooold weather.
Old Jan 4, 2010 | 09:06 PM
nsnrider's Avatar
you can swap the coil pack # 6 with say coil pack # 4 and see if the CEL code would point to #4, if it points to #4, then your coil pack is toast, if it points to # 6 again, then it could be your wiring harness/connection.
Old Jan 5, 2010 | 11:17 AM
UGAd13's Avatar
good thinkin'
thanks!
Old Dec 8, 2011 | 12:23 PM
fhs8860's Avatar
Hi
I am having this exact same issue.
what did you do to fix it.
thanks
Faisal
2003 maxima
67k miles
Old Dec 10, 2011 | 09:33 AM
FirstCarMaxima's Avatar
I've had the same issue. I just got a 2000 Maxima for my first car, and it wouldn't stay running when it was cold. I just changed my spark plugs today, which was apparently a first in this car's 218,000 miles. It seems to work fine, but I'll give it a week and see how it's doing then. I really don't want to have to buy new coils at 60 bucks a pop.
Old Dec 11, 2011 | 05:32 AM
UGAd13's Avatar
It was a bad coil.
Old Dec 13, 2011 | 01:27 PM
HOSTvallo's Avatar
Try testing your coils one at a time.. there is a write-up somewhere on the Z32 forums over on Nico of doing this.. I'll see if I can find it. I would recommend replacing all coils though if replacing one. Though, if you can't afford it then this would be beneficial to you.
02PearlSE
Oct 7, 2015 02:12 AM
bc992164
Aug 26, 2015 12:19 PM
mclasser
Aug 23, 2015 09:32 PM
acw
Aug 13, 2015 12:50 AM
kirkhilles
Aug 8, 2015 10:53 AM
