Coilover install going wrong
Old Jan 12, 2010 | 03:09 PM
Rood's Avatar
Okay so I bought some k sport coilovers for my 2000 maxima.
I installed the fronts with no issues to begin with. Put the wheels on and was ready for a test drive. All of a sudden my steering wheel is going all over the place as I hit some small patches of slush or snow.. I figure I just need an alignment.. Well when Im driving my steering wheel doesnt stay in the middle. When I make a hard right and go back to going strait the steering wheel stays at about a 30 degree angle right.. Same when I take a left it sometimes then stays on the left 30 degrees..
Is this just alignment? Camber? Did I break something somehow not even knowing it? Ive pulled my suspension before and have never had an issue..
What are your thoughts?
Old Jan 12, 2010 | 03:30 PM
HotshotVQ35's Avatar
you need an alignment, when i put my stock suspension back in, the wheel was tilted like 30 degrees to the right. alignment fixed it
Old Jan 12, 2010 | 03:34 PM
Rood's Avatar
Yeah but me wheel doesnt just stay to the right... sometimes its in the middle, sometimes its to the left.. all about 30 degress...
Old Jan 12, 2010 | 03:38 PM
perkman87's Avatar
something is loose.
Old Jan 12, 2010 | 03:42 PM
Rood's Avatar
Originally Posted by perkman87
something is loose.
I figure I just cant imagine what it would be...
I only removed the suspension nothing else. Any ideas would be great, im going in for alignment friday
Old Jan 12, 2010 | 03:45 PM
thats weird that it does it all over the place. its only 5 bolts on each one, start by double checking that
Old Jan 12, 2010 | 03:50 PM
Rood's Avatar
Everything is snug tight, wheels included. Even has a FSTB on the top 3 and those are solid. Im not sure why its just acting weird. Not sure if it has to do with alignment or not or the slight camber on some winer tires..
Old Jan 12, 2010 | 03:56 PM
perkman87's Avatar
Alignment would be first on my list, when you get this done tell them to check the camber bolts.
Old Jan 12, 2010 | 04:50 PM
Grand_hustle17's Avatar
yea alignment, even with alignment it may still feel a tad strange, just not as bad as u explained
Old Jan 12, 2010 | 04:58 PM
Rood's Avatar
the car does not pull at all.. Turns fine and everything, accept when your done turning the wheels tends not to stay in the middle, mostly to the right 30 degrees, but not always. Acts strange
Old Jan 12, 2010 | 05:03 PM
yea, i kinda noticed the same with my k-sports also, its nothing wrong, i bought mines new... i cant remember if pulled left or right... some bumbps i het will pull the wheel like that too... how low are you??? any pics?
Old Jan 12, 2010 | 05:13 PM
Rood's Avatar
I can get pics up friday, as I only have the front CO's on.
The rear bolts are seized... I used PB blaster, Breaker bar, cheater bar, and a floor jack. Wound up breaking my craftsman socket. I got a new socket and tried my air impact. No go. Took it to my shop today and the part holding the nut still broke so the bolt and nut is spinning freely. OMG. I have to order new bolts and nuts ($20 from the stealership), as they are going to cut the bolts out. Well thats upsetting being that my rear struts will be trashed (only 70k on them) and they will be installing my rear CO's. Something I would rather do, as its a easy job.
But tomorrow im getting new rims
After the alignment and complete install with rims, I will put pics up
Old Jan 12, 2010 | 05:15 PM
dont worry bro, the exact samething happened to my with my 02 and my JIC coilovers, the rear bolts seized and i had to take it to a shop also all cool though
Old Jan 12, 2010 | 05:53 PM
ridinwitha35's Avatar
My steering wheel would do the same (not fully return to center after a turn)...but I just had a new rack put in & hadn't got an alignment. Got an alignment the next day where the only stuff out-of-spec was the front toe (off by a full degree on both wheels) and that cured the return-to-zero issue.
I don't know how coilovers work but if it applies, make sure the right one is on the right side. Also try turning extreme left/right while moving...hear any sounds?
Old Jan 12, 2010 | 05:57 PM
Rood's Avatar
Its just upsetting lol.. Paying by hour and such
No sounds when turning it all the way.. Hopefully everything will be perfect after the alignment
Old Jan 12, 2010 | 06:09 PM
PulsarGTS's Avatar
Bad alignment, but keep in mind with the much stiffer springs of the coilovers the car will follow ruts and crowns in/on the road more. Like when switching lanes on a well worn road.
Old Jan 12, 2010 | 06:15 PM
Rood's Avatar
My cut lowering springs was def much stiffer than my coilovers
Although the both have pros and cons
Old Jan 12, 2010 | 07:33 PM
beefy23b/97's Avatar
do they have pillow ball mounts? they could be loose.
Old Jan 12, 2010 | 08:25 PM
I think u said that as best as possible, I was actually sitting here thinking how can I put this to him
Old Jan 12, 2010 | 08:30 PM
jasonmax's Avatar
front tires slipping on a sloped surface will make the steering wheel seem crooked, its called understeering.
drive on a flat surface with good condition to test straightness
gravity is pulling the slipping wheels to the lower side, youre correcting the direction thus crooked steering wheel
Old Jan 13, 2010 | 11:22 AM
SuperStasiu's Avatar
my question is why are you putting coilovers and new rims on in winter? KSports are known to fail in winter cause of the cold
Old Jan 13, 2010 | 11:41 AM
MoncefA33's Avatar
I spoke to Grand Hustle about the K-sports on his last 5th gen and he had no issues with failure
Old Jan 13, 2010 | 12:06 PM
Rood's Avatar
Because I needed an alignment really bad anyways..
So I thought I would install my coilovers and then get an alignment..
Well then I decided to lower it more with new wheels too...
There is my reason.
Old Jan 13, 2010 | 07:30 PM
There is my reason.
well i've heard from people that the seals on shocks in the coilovers fail do to the cold weather plus why would you wanna ruin a new set of rims with all the salt they dump around here
Old Jan 13, 2010 | 07:35 PM
Rood's Avatar
Just trying to get everything done before I got back to college..
Old Jan 15, 2010 | 11:47 AM
J2FRESH's Avatar
sweet, waiting on pics
Old Jan 15, 2010 | 04:05 PM
Rood's Avatar
I dropped it too low..
Y pipe and crossmember were scraping agains the ground..
Time to raise it haha
Old Jan 15, 2010 | 06:48 PM
Rood's Avatar
PICTURE:
DONE FOR NOW:
MaxLife17
Jun 27, 2019 01:37 PM
BkGreen97
Apr 2, 2016 05:47 AM
220k+ A32
Sep 11, 2015 02:18 AM
Johnny9595
Sep 3, 2015 05:18 AM
