HID Installations
Old Dec 4, 2001 | 10:19 PM
csyeo's Avatar
HID Installations
Does anyone know where in Houston area can I find people or shop willing to help me install the 2k2 headlights in my 2k1 maxima? After reading the writeup on installation, Somehow, I realized why I am not in engineering school....
Old Dec 4, 2001 | 11:08 PM
serin's Avatar
it may be bit intimidating to just look at em. but if you try it out, it's not really that bad. if you realize it's just not for you, you can always splice everything back together the way it was stock no harm done. the original wires are all color coded so it's pretty fool proof.
hell, for what a dealer would charge you, i don't think you want him to try figuring it out anyhow.
if you're so inclined maybe you can try daveb at town north nissan. i know texas is huge, but i'm in california and have no idea how close that is to houston. but it's an option.
Old Dec 4, 2001 | 11:16 PM
csyeo's Avatar
Truthfully speaking I would Like to try... the only problem is that I do not know what to buy from radio shack and what connectors to buy and where can I get them... and also where to buy the required tools... Maybe you can help me with that.... BTW are you a guy or a girl? I have a friend whose name is exactly same as your screen name... hehehe
Old Dec 4, 2001 | 11:35 PM
serin's Avatar
stick to the original writeups from either bigdog or ice. then go to pep boys to buy everything. there's a parts list with both writeups. instead of butt connectors, i use quik-connects which are hard threaded plastic things that go inline with the wires you're connecting. makes life pretty easy, especially if you have to redo something. also, just make sure you get a good quality wire stripper.
for the relays, radio shack has what you need. but i didn't use any in my setup.
i'm a guy btw
Old Dec 4, 2001 | 11:51 PM
csyeo's Avatar
i'm a guy btw
BTW whats splicing tool, and whats the diff between butt and quik connectors? are they of the same shape.... So Am I right to assume that the connectors will fit into the light units or Do I have to cut the wires on both side and connect them with connectors? BigDog's write is clear except for some minor details.... also, does your HID units comes with the 2k2 clip? I am getting mine soon
HAHAHAA my friend is a girl.... hehehe
Old Dec 5, 2001 | 02:08 AM
Colonel's Avatar
Old Fuddy Duddy
Make sure you get the 2k2 clip or it will "jiggle". I would recommend that you solder the connections together rather than butt connectors and quick connectors. Everything you need you can get at Radio Shack.
1) Soldering iron
2) Solder
3) Shrink tubing....get two packs.
You just put a piece of tube over one side of the wires, away from the heat, wrap the two wires together so the look like the first part of tying a shoe before creating the loops, solder up (heat the wire, not the solder) then when the joint is COOL, move the tube over it and hair dry the tube till it is tight! It is way easy....trust me and yourself and will make for a much better connection. Plus a degree of water resistance....
When following the instructions, take your time...go slow...not a race who cares how fast and it will make perfect sense!
Good luck
Old Dec 5, 2001 | 03:05 AM
myktek's Avatar
hey guy, tanmann9 help me install my 2k2. . .he lives toward sugarland and i live towards friendswood. . .PM him, he might help. . .he knows more then i do. . .i can help u install them if u want. . .but we'll have to look at mine to see the wiring diagram. . .i just capped mine, didn't really feel like solidering it . . .i've had it almost a month, and no probs. . ..LMK. . .PM me...
Old Dec 5, 2001 | 04:10 AM
UMD_MaxSE's Avatar
Got Bent?
I used those butt connectors and wrapped them up with electrical tape for now. I will probably go with a better connector setup later... for now, it seems to work just fine.
Old Dec 5, 2001 | 10:21 AM
csyeo's Avatar
1) Soldering iron
2) Solder
Good luck
I have yet to recieve my lights.. but in the case where my lights do not have the clip, where can I get it from?
Old Dec 5, 2001 | 10:33 AM
UMD_MaxSE's Avatar
Got Bent?
if you got them from MONTARABOB, the clip will be included...
Old Dec 6, 2001 | 08:36 PM
serin's Avatar
if not, call daveb. he'll hook you up.
and yeah solder if you can. i was/am too lazy to run an extension cord to the parking lot.
Old Dec 7, 2001 | 01:02 AM
Colonel's Avatar
Old Fuddy Duddy
Inlaws garage.....he he he I am fortunate. The driveway dips down before goin into the garage so I put a chair where I was working and the area was low enough that it was like working on the table....
Soldering is not tough though and only takes a moment longer and a MUCH better connection. Plus the shrink tubing offers more protection (I also smeared silicon on each edge to seal it in). But hey....to each their own...I am **** retentive about everything!
MaxLife17
Jun 27, 2019 01:37 PM
Vistance
Sep 17, 2015 05:17 AM
MidnightMaxima_22
Sep 12, 2015 06:02 AM
mpbclutch33
Sep 8, 2015 06:21 PM
MaxLife17
Sep 8, 2015 02:36 PM
