Where can I find a carbon Fiber gauge bezel?
Old Jan 14, 2010 | 05:24 AM
KJVA67's Avatar
STUCK IN ATL
From: JACKSONVILLE, FL. STUCK IN ATL FOR THE TIME BEING
I have seen at least one max here with a carbon fiber gauge bezel, instead of the oem black. Anyone know where I can order one?
Old Jan 14, 2010 | 06:49 AM
LongIslandMax's Avatar
Check ebay.
Old Jan 14, 2010 | 09:13 PM
WhoDatBuuL's Avatar
http://cgi.ebay.com/ebaymotors/2000-...40110001r13800
Old Jan 15, 2010 | 05:21 AM
KJVA67's Avatar
STUCK IN ATL
thanks.
Thanks, ordered it this am. My Paradox rings should be on the way also.
Old Jan 15, 2010 | 10:22 AM
Mr. Brett's Avatar
Will the Paradox rings fit with the carbon fiber overlay...? I think you might end up having to pick one or the other. I think the chrome rings are designed to lay flush against the OEM gauge cover.
Old Jan 15, 2010 | 10:37 AM
toastedoats's Avatar
I have the ebay CF overlay and doubt the paradox rings will play well with it. My overlay isnt quite a perfect fit either which would make it even less likely that it would work together
Old Jan 15, 2010 | 10:38 AM
Mr. Brett's Avatar
Got ics:?
OP, if you do get them to work together, post up the final result and show us.
Old Jan 15, 2010 | 06:32 PM
scottygill's Avatar
I regret sticking my CF overlay in there as well it sucks. need a brushed aluminum one
Old Jan 21, 2010 | 02:40 PM
KJVA67's Avatar
STUCK IN ATL
Thanks for the help folks. Job is complete.
Thanks for all the help. I just finished the job. I may revisit it at some later date to tweek it, but for now I'm good. It does make me realize how dim the OEM lighting is on this dash. It doesn't quite match the carbon fiber on my Momo ****, but it's close enough for now.
Take a look.http://www.facebook.com/photo.php?pid=152949&id=1726478855http://www.facebook.com/photo.php?pid=152949&id=1726478855
Old Jan 21, 2010 | 02:43 PM
bigpopaj369's Avatar
i want one! looks pretty sicky
Old Jan 21, 2010 | 02:51 PM
KJVA67's Avatar
STUCK IN ATL
Don't think the pics worked. but they are in my photo album if ya wanna peek.
Still a lil much tech for a old man.
Old Jan 21, 2010 | 03:51 PM
Mr. Brett's Avatar
Fixed.
Edit: Just kidding. You need to go to the pics on your facebook, right click on them, hit properties, and use the URL listed in properties.
On a side note, it does look really clean. Surprised the hell out of me. Very modern looking.
I may be doing this in the near future. Probably when I install my LEDs in my dash.
Old Jan 24, 2010 | 11:03 PM
a33_ridah's Avatar
can u put pics here for rest of us to see?
Old Jan 25, 2010 | 06:43 AM
Mr. Brett's Avatar
Go to the OP's profile page on here. He has an album of pics.
Old Jan 26, 2010 | 08:10 AM
KJVA67's Avatar
STUCK IN ATL
in my photo album. click my name in blue, go to profile
Old Jan 26, 2010 | 08:18 AM
KJVA67's Avatar
STUCK IN ATL
Ok. Got the pics to work.
Take a look.
Old Jan 26, 2010 | 04:48 PM
a33_ridah's Avatar
that looks sweet!
what kind of tweaking did it need? a little trim here and there?
Old Jan 27, 2010 | 04:08 AM
KJVA67's Avatar
STUCK IN ATL
Alterations
The panel is made for a Maxima with a stick, not the Auto. If you want to see the Gear indicator, (P,R,N,D) You have to cut out a opening for them. I also tend to worry about things staying in place, so I may add some adhesive to make sure it says in place.
When you add these pieces to your dash, it reminds you of how dim our lighting is. If you have the time, this would be a perfect time to upgrade your dash lighting to increase the amount of light on the dash. I didn't have a plan for my upgrade so I will address it later.
Old Jan 27, 2010 | 09:38 AM
Looks like yours had the same slight misalignment issue as mine at the top of the speedometer and odometer gauges. I didn't bother cutting out the shifter indicator on mine, I can look down if for some strange reason I forget what gear its in...
Old Sep 30, 2010 | 01:48 PM
slaught1687's Avatar
hey - where'd you get those chrome rings from? I can't find them anywhere
Btw - do 4th gen rings fit on the 5th gen?
captchaos
Mar 15, 2016 12:18 PM
97_GXE
20
Sep 17, 2015 08:12 PM
NissanNismoZ
Sep 12, 2015 07:30 AM
asianstyle
Sep 10, 2015 11:30 AM
Violator
Sep 9, 2015 10:14 AM
