I want to overhaul my engine, where should I start
Old Feb 26, 2010 | 04:49 PM
  #41
SteveB123's Avatar
It would probably be easier to use a cam from a reputable manufacturer, rather to try and design your own.
You seem concerned with maximum lift, what class are you running in, what power band are you searching for, since obviously it's not a DD anymore?
Old Feb 26, 2010 | 05:00 PM
  #42
jrflores's Avatar
I do want it to be drivable everyday, i was concerned about clearance because i will be using aftermarket cams for a VQ35 and i was concerned with them not fitting correctly...im a noob tuner and an engineer so maybe i got to carried away? haha
so i guess what your saying is that any aftermarket cams for a vq35 will have no clearance issues in my vq30? Maybe thats the question i should have been asking.
as far as class is concerned i dont know the tier of tuning for i wouldnt where i fall.
Edit: I just want a quicker car. not gonna be tracking it or anything. just wanna learn...so i can play with the "big kids" so to speak, lol.
Old Mar 1, 2010 | 02:53 PM
  #43
jrflores's Avatar
Oil pump is usually around $100
VQ35HR valve springs/retainers/double shims is $215 brand new if you call Dave Brunette at South Point Nissan
As for cams, check the G35/350Z forums for some JWT, Brian Crower, Tomei, etc. You'll have to do some research with this since picking too aggressive cams will push your powerband way too far up and ones that aren't aggressive enough won't give you the kind of power you're looking for.
hey moncef, i ordered only 24 shims and i remember you saying to double shim the springs, why is that?
also, i don't want to lose too much low end power. what kinda of cam would you recommend so that i get noticeable power but minimal low end losses?
Picking cams has proven to be a lot more difficult than i expected.
Old Mar 1, 2010 | 02:55 PM
  #44
MoncefA33's Avatar
Mainly an insurance thing. If you're running super aggressive cams, its recommended but if you're not running too aggressive of cams you'll be fine with HR springs.
Probably go with either RevUp VQ35 cams, the JWT S1 (VQ35 version) or the JWT S1 knockoffs. Get cam adapters from Stephen Max to run the VQ35 cams in your 3.0L.
Old Mar 23, 2010 | 12:30 PM
  #45
jrflores's Avatar
Just ordered more stuff
Rev-up Oil Pump-178.54
Overhaul Gasket Kit-257.00
Front Engine Mount-74.24
Coolant Reservoir-53.88
Radiator Cap-11.50
Remaining HR Shims-29.76
Water pump-81.00
Should I order new Head Bolts?
I'm still looking for cams,Stephmax adapter. Greddy Emanage Ultimate, and A/F wide Band =/
so far I've dropped just shy of 1k.
Old Mar 23, 2010 | 04:29 PM
  #46
jsouza's Avatar
Hey jrflores, u planning on replacing bearings or are u just doing beadwork? From
the look of the bores and pistons u might want to check them out. Nice post, deff cool seeing the progress. I have to rebuild mine soon as well, I need a thrust bearing. Im
deffinately following this thread
Old Apr 15, 2010 | 11:51 PM
  #47
jrflores's Avatar
what up every one. I Recieved my cams today =). i ended up getting NISMO R cams from Andyman
Used Nismo R cams-$600
now i just need adapters and i can take the heads/cams springs...etcs to the head place. they quoted me $350 for both heads: to resurface, do the valve job. does this seem reasonable?
Jsouza-as far as the bearings on crank shaft, you got me thinking, is there a way to know for sure if i need to change them?
also, another thing the i have noticed is that my cranck shaft and pistons wont rotate. this the what it looks like now
Old Apr 16, 2010 | 04:31 AM
  #48
SteveB123's Avatar
Measure.
Old Apr 21, 2010 | 05:13 PM
  #49
jrflores's Avatar
Today I dropped Off the heads, cams, springs,shims...etc at Same Day Heads in Fullerton.
Old May 6, 2010 | 12:25 PM
  #50
jrflores's Avatar
soo, Today i Found out The Machine shop snapped one of the cams -__-
the guy told me that they were making the final adjustments and when they tightened it down it just snapped.
Now they are making some with the same grind.
Has this happened to anyone before?
Old May 6, 2010 | 12:49 PM
  #51
Grand_hustle17's Avatar
Originally Posted by nzelinsky
You should pick up a vq35 and then you can hit some extra power!
why was i thinking the same thing.... why not do a 3.5????
Old May 6, 2010 | 12:59 PM
  #52
jrflores's Avatar
haha, ive gotten this alot.
haha, I'm having a lot of fun doing my overhaul. not looking to be the fastest max or anything. I want to gain knowledge and develop my hobby...take it to the next level.
Besides these VQ30's have a lot of untapped potential.
http://forums.maxima.org/dyno-discus...k-ruh-roh.html
Old May 6, 2010 | 02:00 PM
  #53
no matter with all the potential you think or know the 3.0 has,
VQ35 with just boltons...
http://forums.maxima.org/1-4-1-8-mil...b-12-58-n.html
Old May 29, 2010 | 11:52 PM
  #54
adamsanders's Avatar
How is the overhaul coming along?
Old May 30, 2010 | 08:36 PM
  #55
Nucho's Avatar
Man you are on your way. Excellent research.
Old May 30, 2010 | 08:41 PM
  #56
MoncefA33's Avatar
Let the man build his 3.0
I wanna see how those Nismo Rs are! I've got RevUps chillin, waiting to get put on
Old Oct 16, 2010 | 06:00 PM
  #57
jrflores's Avatar
Hey YAlll! it has deff been a while. Im very close to finish up my build but I'm not sure if im putting my Stephen Max Cam adapters in right, it just feels wrong, I was hoping someone who has used them before would chime in. her is a pic of how i have the in now.
http://www.facebook.com/photo.php?pi...a&id=502776547
reason why it feel wrong is because the pin is on the intake side is now 180 degrees from were it originally would go. Input please, i wanna finish it up this week.
sorry i haven't been updating but not much was going on while i looked for replacement intake cams. I ended buying them from Brian Crower (stage 2), almost the same as the Nismo's. I need to update my parts list too but ill get to that a lil later, i wanna feel certain about these adapters, last thing i need is to put everything together and the engine not running.
thanks in advanced!!
Old Oct 23, 2010 | 01:50 PM
  #58
jrflores's Avatar
SHES ALIVE!!!!!!
SOUNDS SUPER MEAN TOO!
Old Oct 23, 2010 | 05:16 PM
  #59
jrflores's Avatar
pics i forgot to upload...
Old Oct 23, 2010 | 05:17 PM
  #60
jrflores's Avatar
Old Oct 23, 2010 | 07:30 PM
  #61
MoncefA33's Avatar
OMG
More pictures, videos...
In for more build info and #s
Old Oct 23, 2010 | 07:47 PM
  #62
CraigSE's Avatar
Nothing like a naked engine.. I love these pics.. If I ever need to do work on mine internally, bring it!
Old Nov 19, 2010 | 04:09 PM
  #63
jrflores's Avatar
Updates!
Finally added up how much i spent total just on part from Dave B and it came out to $1,691.20 Plus an extra 450 for new intake cams from Crower. i must say though it was very well worth it.
Hadn't updated because i was busy trying to get everything in and working
Everything is running great now, Just passed smog today with no issues, well except that i had to drive alot of miles before all my Status Monitor were all complete.
I was planning on driving it for a while without tunning it. Does anyone see any issues with that? Moncef, if you could chime in on that.
Im trying to find a Dyno near by so i can see what just the cams, springs...etc did, i def lost some low-end torque and HP but i'm hoping i can fix some of that with the tuning, on the top end i can really feel the power increase. Also, it stalls at idle sometime usually when its warm...oh and my mileage kinda blows now, ahaha.
as far a vids, I'm a noob, but ill try to figure it out.
Old Nov 19, 2010 | 05:19 PM
  #64
trooplewis's Avatar
I'm impressed with the work that you did. Did you do anything at all to the crank, or just mess with the top end?
It would be fun to have a "spare" 3.5 engine and be able to do all that stuff to it then just swap them out when it was finished.
Old Nov 19, 2010 | 05:46 PM
  #65
MoncefA33's Avatar
@ stalling at idle.
I'm glad you got everything running properly man. Hopefully my build can match yours, I have the software so now I just need the hardware
It's hard to predict how the car runs now in terms of AFR, but I strongly recommend getting a wideband to see where the car is at. If your AFR is lean (13.6+) it will be a little unsafe to run it too hard, whereas if your AFR is rich (12.5 or lower) it will be safe to beat the car. Either way, you will need to tune it to get the most power out of the cams.
I have an e-Manage Blue and SAFC2 for sale so let me know if you're interested in either. I'd recommend at least going with the Blue since it can datalog, control the AFR via injector signal rather than airflow signal (sometimes manipulating airflow signal also screws up your timing), and it can raise the rev limit which will highly benefit your effective powerband.
Get those videos up! Just start a YouTube account and upload them.
Old Nov 24, 2010 | 02:33 PM
  #66
jrflores's Avatar
Video!!!
Haha, So i popped my Video Cherry!
http://www.youtube.com/watch?v=8lBBMYPhR5g
so i guess my priority list is now:
Wash Car, you can all prob agree with that after you see the video
Wide Band AFR guage- i was leaning towards the AEM UEGO
Tuner
New Exhaust Syst, I really hate the way the oval one looks.
Moncef, Thanks for the offer, I was planning on getting an EMU but i guess if the price is right for that e-manage blue i wouldn't mind running that for a while.
trooplewis, thanks man, i had a lot of fun and learned a ton. oh and yeah i only messed with the heads.
Old Nov 24, 2010 | 06:01 PM
  #67
RLW001's Avatar
Good read on All Motor VQ35DE Nissan Engine build from Import Tuner Magazine.
http://www.importtuner.com/syntectop...ine/index.html
Nissan VQ Street Cam Shootout - Tech
http://www.modified.com/tech/modp-10...cam/index.html
Old Nov 24, 2010 | 08:05 PM
  #68
CMax03's Avatar
Definitely read first!!!! But here's a really serious question: Have you ever overhauled an engine b4? If not,...I think (personally) this is a bit much for a beginner!
Old Nov 24, 2010 | 08:14 PM
  #69
rroderiques77's Avatar
Demodded and Forgotten
I'm sure he would have done just as good with a DEK. This is more driver than motor.
MAXSE5SPD
Sep 17, 2022 04:00 AM
mvm062
Nov 30, 2020 09:00 AM
Matt93SE
May 24, 2019 02:58 PM
A32goldylocks
Sep 2, 2015 06:39 AM
